Results 1 to 11 of 11
Thread: Sena Questions
    Dec 2014
    Garland, Tx (near Dallas)
    Default Sena Questions
    I just got a Sena dual system and have some questions. I'm installing them on modular helmets.
    1. Should the microphone be right in the middle in front of your lips or is it ok to have it slightly to the side - still in front of your lips, but just a little off center?
    2. Do you use the microphone cap to reduce wind noise?
    3. Is there a wall charger available? It comes with a cigarette lighter type charger and a USB, but no wall plug charger. When we are at Spyderfest, I want to be able to charge the units at night while at the hotel. I don't have a laptop, so nothing to plug the USB into when away from home.
    Jul 2014
    Central Ohio
    The mic can be off center, it won't hurt with sound transmission. The foam wind sock will filter out a lot of wind noise. Use your cell phone charger when in the house or at a hotel.
    John
    Very Active Member GunDoctor's Avatar
    Sep 2014
    Los Angeles
    Ditto..USB ports are pretty standard in hotels these days.
    2015 F3-S. And Another Day To Be My Kids Dad
    Very Active Member Bam Bam and Pebbles's Avatar
    Nov 2014
    Rural Hall NC
    Quote Originally Posted by Professor View Post
    MY wife and I use 3/4 helmets with our Sena's. We have the microphone just off to the side and a bit above our mouths, inside the face shield. We dont use the cap and haven't had too much problem with wind noise. We can hear each other fine. I don't know if a wall charger is available but you can by a USB wall plug adapter. Plugs into the wall and the USB plugs into it. Same thing that comes with IPhones.
    Current Ride
    2015 RT-S SM6 Cocaine
    Pearl White
    Diamond R Web Armrests
    Shorty Windshield
    Previous Ride
    2012 RT SM5 The Beast
    Pure Magnesium Metallic
    Jul 2014
    Mint Hill, NC
    The user's guide will tell you just about anything you need to know. Any certified USB charger can be used to charge a Sena headset.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Dec 2014
    You are all the GREATEST!!!
    Thank you soooo much.
    1. We put the mic in the middle close to the lips without touching--less wind noise. Mic goes behind the face plate to keep it out of the wind.
    2. Mic cap on at all times.
    3. We use wall chargers, I think I had to order mine separately.
    Ours are installed on Nolan 40 series helmets. Open face variety, but we use the pull down face plates that come with.
    Dec 2014
    Thanks again. I just found out that my wife already has a wall charger with two USB ports. As usual, she is way ahead of me.
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    The wife found us a plug in surge protector with 120v and USB plugs. Good charging point for the headsets, our tablets, the laptop if I take it, etc. It's the same size as the converters that turn two outlets into six.
    Active Member cougar's Avatar
    Alpharetta, GA
    I don't use the boom mic. I installed the wired mic. Works great and does not interfere with putting helmet on or off.
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Why not just charge them in the Trunk.
    I purchased a 2:1 cigarette adapter and plug my 2 Sena cords in.
    BTW several 2:1 USB adapters are also available and combos of cigarette and usb.
    Just remember to move the fuse so power is available when ignite is off
    AJ
    Quote Originally Posted by Bam Bam and Pebbles View Post
    2014 RT/S , Black
