Results 1 to 17 of 17
    Mar 2015
    New York
    Default ICSI hand brake and Tri Axis Adjustable Handlebar
    I was checking out the hand brake, I am definitely going to need one, but all I see is it on regular width bars. Does anyone have it on the Tri Axis adjustable handlebar? It is quite different than regular bars. Does it have a special fitment for this particular bar?
    Mar 2015
    New York
    Nevermind! I found it. I jumped the gun and found it right after I asked. Sorry to waste board space. Mea culpa, mea culpa...
    Mar 2015
    New York
    But since you're already here... is the ICSI the best hand brake system out there? It looks incredibly well-made.
    Default Not sure..!!
    but if no one here has installed one you might get in touch with them and see if they have a model for the tri axis bars. if they don't have one now they will soon. Many folks are getting those bars...
    ​2012 RS sm5
    Active Member rays hell's Avatar
    Hiram Ga.
    Default hand bake
    It may be the best one out there. But it is also the only one out there.
    With that being said it is way out of my budget.
    I've read that they don't make one with a cable because, cables fail, but found out the emergency brake is held by something.
    Oh yeah it's a cable...........................
    Very Active Member DR Buck's Avatar
    Apr 2012
    Fauquier County VA - Virginia's most carefully pronounced county.
    I put the ISCI on my adjustable bars almost 2 years ago. Works great. Pictures in my gallery. Follow the link below.
    2012 RT Limited - Pearl White
    My Mods -
    http://www.spyderlovers.com/forums/showthread.php?39494-DR-Buck-s-2012-RT-Limited-Mods
    2012 RT Limited , Full size brake peddel White w/Red Highlights
    Mar 2013
    I have both the Tri-Axis handlebars and the ISCI hand brake and they work well together. The only thing is that the ISCI doesn't come with the plastic cover (under the bar) that needs to be modified for the hand brake to fit through. It comes with one for the standard bar so I copied the cut out onto the cover from the Tri-Axis bar.
    Just take your time and use small cuts until it fits.
    I don't know if anyone else makes one, but the nice thing about the ISCI unit is that it doesn't tie directly into the brake system so if it ever failed the Spyders brakes will still work as designed. That and it is a very well made kit.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Mar 2008
    Hesston, PA
    Default Hand brake & tri axis bars
    I also have the hand brake kit on my 2014 RTS with the tri axis bars...I installed bars and hand brake at the same time...Just takes some time...Looks factory installed when done...
    USA, PA York
    Quote Originally Posted by larryd View Post
    Just remember if you have a small hand order it with the small hand lever. I didn't know that when I ordered and had to then order after install and have it swapped out. I have both the Tri Axis bars and hand brake kit and they work great.
    Traded in - 2013 RT SE5 Limited - Pearl White
    Mods Mods
    Tri Axis handlebars
    GPS mount for the Tri Axis handlebars
    Ultimate seat with driver backrest
    Driver cup holder
    3rd Brake light -truck
    Spyderpops bumpskid
    Bayaron swaybar with Heim links
    Lidlox
    Mar 2015
    New York
    Did you guys use the plastic cover that was included on your tri axis or did you cut the existing one like mentioned earlier?
    Sep 2013
    Houston
    Quote Originally Posted by rays hell View Post
    Your bike does not have an emergency brake. It has regular service brakes that are hydraulic and it has a rear caliper only parking brake that is cable actuated.
    All that aside, unless the rider is handicapped such that the right foot brake cannot work, there is no need for the ISCI hand brake once you learn to use the Spyder service brakes as designed. Its no different than learning to steer the spyder differently that a traditional motorcycle. The Spyder brakes are VERY good at stopping the bike and properly maintain the front to rear bias and are monitored by the ABS system. The ISCI hand break does not split the system front and rear anyway.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Registered Users Dragonrider's Avatar
    Feb 2009
    Canby, OR
    I've installed the ISCI handbrake on my RS SM5, and on a friend's RT SM5. I have ridden Spyder's with both the SE and SM systems. The ISCI system wasn't/isn't the only system out there, but it IS by far the best, and is an exceptional engineering feat - it does a superb job, while just actuating your foot brake. It is worth every penny of the asking price.
    Personally, I've found that I have to have one with the SM box, but don't want/need one with the SE.. Don't know why, just is. The way I look at the SM vs SE decision is that they are the same price (adding the ISCI brake), but do I want to exercise my hand in stop-n-go traffic, or at stoplights? Again, personally, I wouldn't have the SM without the ISCI brake system.
    2014 RT SE6 Rider
    X - Honda Rider
    X - RT S driver
    X - RS driver
    Lifetime VFW Member
    Mar 2015
    New York
    I was on the phone with them this morning, great people! The tri axis "sleeve" on the bottom of the bar needs to be cut to accommodate but doesn't seem like too big of a thing. After researching, and especially talking to them, that is what I am going with. All doubt resolved in one 7 minute phone call. That's a professional.
    Jun 2013
    queens ny
    i love my hand brake. they are great people to deal with and make a quality product.
    NO BIKE AT THIS TIME
    Apr 2012
    You are better off if you use the lower cover that comes from ISCI and trace the tri-axis lower cover and cut off the ISCI. It's much easier then trying to modify the shorter tri-axis lower cover.
    My Mods -
    Active Member gparr's Avatar
    Jun 2014
    Yorktown, VA
    I wonder if we could get them to lower the cost any by doing a group buy....just thinking...
    2014 Can Am Spyder RT Limited - Cognac
    Grip Puppies
    Laser Alignment
    F4 Custom Plus3 Wide with Vent and front blackout
    Baker Built Air Wings
    Ultimate Mid Rider with Driver Backrest
    GearBrake - Smart Brake Module
    Custom Dynamics High Mount Brake Light with Flasher Module
    Lamonster RAM Universal X Grip Cell Phone Holder
    Lamonster RT Spyder Cuff with. 20oz Bottle Holder
    Lamonster FBB Highway Brackets - Dually Trident Black
    Best Warranty until 10/28/2019
    Mar 2015
    New York
    Thank you! That is one hell of an idea! I owe you a beer sir!
    Quote Originally Posted by DR Buck View Post
