Results 1 to 6 of 6
Thread: Ham radio??
    Jan 2015
    Anaheim Hills, CA
    Default Ham radio??
    Has anyone installed a ham radio on a Can Am Spyder GS? I am a licensed amateur radio operator and recently purchased a Yaesu FTM-10R mobile 2 meter/440 MHz radio to install on my Spyder. This unit has a water-proof remote control head and id designed for harsh environments. The biggest challenges are going to fins a place to hide the main unit and a way to mount an antenna, If anyone has mounted a radio and/or antenna, please contact me.
    Mike (KA6ALF)
    Michael R. Douglas
    alfdude@roadrunner.com
    "For I know the plans I have for you", declares the Lord, "Plans to prosper you and not harm you, plans to give you hope and a future" Jeremiah 29:11
    Jan 2015
    Florence, Oregon
    Default Ham Radio Help!
    I use my 5 W Hand Held (HT) with a speaker Mic. I would recommend a "J-Pole" antenna as you won't need a ground plane of metal to properly load the antenna, 1/4 Wave Mag Mounts and such are half of the needed dipole and need a lot of metal beneath them, the "J-pole" does not need the metal ground plane. I do have concerns about the RF from 50/60 watts messing with the on-board electronics that make the Spyder run. KE7GZU 73's.
    Very Active Member WA5VHU's Avatar
    Cooper, TX
    Default WA5VHU Here
    Mike,
    Dr Buck installed his here http://www.spyderlovers.com/forums/s...ighlight=yaesu
    I had my FTM-10R control head mounted on my Spyder's handlebars once but never installed the rest of the radio. I later installed the radio on my Honda NC700X 2-wheeler. For now I use my VX-8 talkie on the handlebars but I am looking for another FTM-10 - they are getting hard to find.
    Current:
    2016 Honda CTX700 DCT ABS (faring model)
    Kip Moto SherpaX Cargo Trailer
    Wife Has:
    2014 Can-Am Spyder RT Limited
    2016 Lees-ure Lite Camping Trailer
    Previous:
    2013 Can-Am Spyder RS SE5, zoom-zoom!
    2011 Can-Am Spyder RT-S SE5, Foot Burner - Gasoline Boiling Stinker - Gas Tank Vacuum Puller
    Active Member Bruiser37's Avatar
    Jun 2016
    Tucson Arizona
    Default Ham mobile radio operation on Spyders
    Quote Originally Posted by Alfdude1 View Post
    Mike (KA6ALF)
    Mike, I think versitility of RAM mount systems offer many options, however you should reconsider a 50 watt rig and possible interference with Spyder can-bus computer system. lack of a good ground plane, higher SWR you don't know where stray RF will be going while communicating. Only good place to safely hide power module is in a luggage case. IMO a hand held 5/10 watt HF transceiver to work repeaters with bluetooth audio & helmet mic would be my choice... D-Star HF handheld rig & repeaters you can talk to the world. Another serious consideration is small moto battery & alternator capacity designed to handle only Spyder electrical systems with very little power left for anything else when on the road.
    Bruce, W1VOT (One Very Old Timer)
    2018 RT Limited Spyder , Garmin Zumo GPS, Battery tender wire harness Show Chrome brake pedal extender Oxford Blue
    Cooper, TX
    A 50 Watt mobile may be a good choice, you can always run it on medium or low power. That will give you a larger heat sink, and running it at 20 Watts or so may keep it cooler.
    I mounted the body of my mobile rig in the frunk on the removable panel that covers the battery. Made it easy to mount and mess with, just the two top screws holding the panel on.
    I transmitted at the full 50 Watts and never noticed any issues with the Spyder, however I normally operated at the medium power setting.
    My antenna was a Diamond 1/2 wave that does not require a ground plane, I mounted it at the back of the trike.
    Current:
    Wife Has:
    Previous:
    Jun 2016
    Tucson Arizona
    Default Ham Spyder mobile
    Quote Originally Posted by WA5VHU View Post
    Very nice Spyder mobile set up. Nothing like real world test...up to that point only hope it works as planned. Good to know no can-bus computer problems and electrical system can handle a 50 watt rig.
    73's W1VOT
