Factory HID kits work with 2014?
Hey guys, does anyone know if the factory HID kits made for 2012 and earlier models will work with 2014? I have an RS-S.
thanks
maybe this link will help
I'm unable to give you any help because I installed the BRP HIDs on a 2012 but... http://www.spyderlovers.com/forums/s...amp-FOG-LIGHTS
Check out this link and contact this person to see if he still have the step by step pics and any info for installing on the newer models.
He installed on a 2013 RSS and I don't see any difference with the 2014.
Hope this get you started.
Thanks! I sent him a pm. I ordered an aftermarket kit since my first post and will be installing it soon, will post a few pictures if it works.
Hey guys
2013 was easy to do I helped the guy with the 14 out with his, the 14 is different but still will work ,the 14 has no jumper harnesses anymore there plugged directly into the the main harness, so as long as you get over the fact your cutting the main upper body harness instead of 2 $20 jumper harnesses
Physically the upper console on the RS and RSS are the same.
Dennis I replyed to your PM. Let me know if you go that way and if you need any help
Bill
2013 RSS Neutron Green
BRP HID's and Fogs
Custom Belt Tension
2014 side panels
HMF Exhaust
K&N air filter
Bajaron sway bar and links
