Zumo 660 GPS & Sena SMH10 Headsets - NEED HELP!!!!!
Hope someone has a solution for me. I recently purchased a pair of SMH 10 headsets. Pairing to Intercom and Phone (Galaxy Note 4) and pairing and connecting my 660 was simple also HOWEVER when I attempt turn by turn Navigation the audio only comes from GPS and not thru the headsets. I've had multiple email correspondence with Sena and one phone conversation. In all cases, I/we were unable to get the combo working properly was finally was told by Sena that apparently my Zumo is defective. Searching the internet, I found many individuals had problems of various sorts. Does anyone have a possible solution/fix for my dilema? Obviously I could my phone for navigation and hear turn by turn in headset but of course that's a heavy drain on the phone and the charging cable would be inconvienent. I also contacted Garmin but only response I got from them was 'is your software up to date'? Any help/suggestions is appreciated.
2012 Spyder RT, Seal Floorboards, Sena SMH10 Dual Headsets
Issue Solved
I performed a Hard Reset on the 660 - viola!!!
2016 RT Limited, Garmin Zumo 660 GPS, Comfort Seat, Wizard LED Accent Lights; Ultimate Trailer;(had) 2012 Spyder RT, Seal Floorboards, 2006 Kawasaki Voyager XII, 1989 Yamaha 850 Special, Sena SMH10 Dual Headsets, ZOX Modular Helmet; Guardian Angel on my shoulder!
Great! Nothing worse than something not working as advertised.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
