New F3 needs a alignment
Picked up F3 last Friday and noticed that it drifts when I let her track on her own. I'm in the Los Angeles area, does anyone know where I can get a laser alignment?
Another Day To Be My Kid's Dad [emoji379]
No..!!
but if you pack a lunch and head to Vegas you will find "Squared Away" and Ann and Joe can fix you up. If you check with them they may be coming to your area as they travel around. Get a group together and they will come to your door.. well maybe not your door but close...
Go to ROLO/Outlaw lazar alignment web page it has all the dealer/ people that has brought the system. I'm sure there is someone that is close by
Take it back to the dealer and make him fix it!
Squared Away in Vegas. Ann and Joe.
Gary
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
Dealer/BRP problem
Why would you spend more money for an alignment?......Take it back to the dealer and make sure they get it right. If everyone continues to bypass the dealers/BRP then there is no incentive for them to get it done properly. Just my $.02 worth.
John
Cape Spear, NF. Most
easterly point in North
America |
Provinces & States visited on
Motorcycle
2 and/or 3 wheel |
In this case it is worth the money to get it fixed right the first time instead of going to the dealer and hearing "they all do that" or a four hour BRP job that makes the handling worse. While I agree the alignment should be right when you get the bike this is not the case. I had a laser alignment done and have no regrets.
2016 F3 Limited
2019 Ryker Rally
2020 CSC TT 250
I'm having mine done by Squared Away in 2 weeks.
Thanks for the reply. Wasn't aware they align after assembly.
Vegas is the closet laser alignment...not practical to take a 8 hour round trip.
Ohhhhhh, Ohhhhhh here comes my very first negative post on the new F3.
A machine costing $20K + should come out of the factory properly aligned. If that continues to be a problem, then, the dealer should have the laser alignment tools and use them properly before sending the new machine out the door. A properly aligned machine should be what comes out the door after dealer prep.
Based on what we read here, a free, laser alignment should be a given with all new 's purchased.
I do not feel that a customer should have to pay additional to get a brand new machine running according to specs.
I agree, but what should be and "is" are two different things.
2016 F3 Limited
2019 Ryker Rally
2020 CSC TT 250
If you can get a group together that wants alignments, they may be able to travel closer to you. Doesn't hurt to ask, they are traveling to Yuma AZ soon to help out a group there.
2016 F3 Limited
2019 Ryker Rally
2020 CSC TT 250
Lou does my work in Riverside (I'm also in in LA).
http://www.piratepowersports.com
Agreed! You only just picked it up! Sounds like dealer responsibility to me.
$20000.00 plus for a 3-wheeled vehicle w/o a heater, radio, air conditioning, or even a roof ain't cheap. And the front isn't aligned?
A simple question here; a "C" series Mercedes Benz is probably comparable in price, vehicle to vehicle. Would you put up with the Benz dealer giving you a mis-aligned vehicle or even listining to him whine and make excuses? I think not.
Make th
Spyder dealer fix it!
I whole hearty agree... its the dealer who should get it corrected... but... good luck in doing so.. BRP does not care either..
osm
Originally Posted by MRH
But Lou doesn't have the Rolo Laser Alignment system. Which is the one endorsed by BRP as the correct way for dealers to align Spyders. That is the system that we, Squared Away, uses.
We would be happy to align GunDoctor here in Las Vegas or if you can get 8 to 10 Spyders together in the LA area we would be happy to come to you. If you host the event your alignment would be free.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Touchy subject. I knew that an alignment sponsor or two would be jumping in.
I have no problem with people earning a living, but a new machine should come out of the dealer according to specs. Why should a new purchaser have to cough up $120 - $150 just to make it right.
Hence my suggestion that a laser alignment should be performed by the selling dealer as a part of the prep package.
And some of the dealers that have bought the equipment do align them as part of the setup. I agree that they should be aligned from the factory but they aren't. So you can complain and suffer through an ill handling Spyder and poor tire life or you can have your Spyder laser aligned. The choice is yours.
2010 RT- 622
I am new to the Spyder world and have not picked up my F3 yet. So what I am to understand is that besides paying over 20000 for my new ride I am being told by several of you that I my need to spend another 150 for a alignment and that is acceptable to you all, all I can say is I wouldn't ever own another Spyder if I end up paying for a alignment on a brand new bike so my dealer will get it right or by by Spyder for me.
SpyderLovers Sponsor
CALL ME CRAZY BUT.......
If I had just dropped 20+ thousand dollars on a NEW Spyder and it was out of alignment it would be back
in the dealers hands faster than you can say fix it... Same with a new car if something is not right with it
take it to the dealer you got it from and let them know you expect it to be correct when you buy it and you
expect it to be correct when you come back to pick it up at NO CHARGE...
Why would you pay for an alignment or any other service for that matter that should have been done by the
Manufacture or dealer.... In California there is a division in the state called the B.A.R. Bureau of Automotive Repair
If your dealer and or BRP will not pay for it BAR will be happy to remind them that if they are currently enjoying doing
business in California and wish to continue and be licensed to do so they WILL fix your alignment to your satisfaction.
That is only my opinion.... and you all know about opinions....
Ride Safe
Dave
Take it back
I agree, most of good dealers are going to do it for free for you.
give it a try
I will be calling them Monday to ask if or what was used to align my Spyder. Thanks for all the comments.
