Page 1 of 2 12 LastLast
Results 1 to 25 of 34
    Jun 2010
    Las Vegas
    Default Changing spark plugs
    It is time for me (not me but Joe) to change the spark plugs on my 14 RT. I am wondering if anyone else has done this yet? The service manual is pretty vague on what needs to be removed to access them. They refer to removing the 'front body module' in the section on air inlet removal but they don't use that term again in the BODY section. The section on spark plugs has no information at all on what panels to remove. In my manuals for 2010 & 2013 the section on spark plugs listed the panels that needed to be removed. No such luck on the 14 and my dealer hasn't done spark plugs on one yet.
    One good thing is the air filter on the 1330 is much easier to access and change than it was on the 998.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default THEY HAVE A VIDEO
    Ann go look at the video that was done on the complete dis-assembly of a 2014 RT......I think they are referring to the entire front section which comes off as one piece.....I think it was 10 easy to access bolts and a couple of plugs to un-couple ..........Mike
    Default What..!!
    you all have no service manual..!!?? May I suggest pulling the engine..makes it a breeze.. sorry, never looked into it.. but if you bring it by I will change them..love puzzels...
    Jun 2010
    Las Vegas
    Mike:
    Any idea on where I might find that video or who filmed it? 10 bolts and a couple of plugs sounds way too easy for a Spyder.
    2010 RT- 622
    Default LOOK HERE
    Quote Originally Posted by SpyderAnn01 View Post
    Mike:
    ..................Ann sorry I can't do links , but...........in the Search box I typed ....2014 RT Video.......and about #8 down "Dragonrider" asked for the similar info,,,,,,,someone posted THE VIDEO YOU WANT about two posts down , in the thread................sorry this is so complicated..............Mike
    Jun 2010
    Las Vegas
    Thanks Mike. Sometimes searching here is a pain. There is almost too much info. I'll be sure to take a look at that post.
    2010 RT- 622
    Sep 2013
    Harper, Texas
    It is about the worst MC manual I have run into yet. However, the ignition coils removal (stick coils) is listed out. Can't guarantee this is all you would have to take off.
    Ignition Coil Access
    Refer to BODY subsection and remove the following:
    - RH and LH upper side panels
    - RH and LH acoustic panels.
    Refer to AIR INLET SYSTEM and remove the primary air inlet silencer (air filter housing)
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    Here is the video of removing the frunk that I saved. Not sure if there are any difference for the 14's.
    Watch "How to remove the Boot (frunk) on a Can am Spyder RT" on YouTube
    How to remove the Boot (frunk) on a Can am Spyder RT:
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Danbury Connecticut
    Quote Originally Posted by M109Dreamer View Post
    Thanks !
    I'm not changing my plugs, rather I want to replace the foglights so the color matches the HID's I have.
    I'm surprised, but you have to remove the frunk to replace the bulbs.
    Sorry, I didn't mean to hijack the thread.
    And now, back to our regularly scheduled program.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Active Member Doc - Riverside's Avatar
    Jan 2010
    USA Folkston,Ga
    Default This should give you an idea
    The spark plugs are buried. Looks like the Frunk has to come off, the top console and a bunch of plastic associated with the air box.
    ace head.jpgace head 2.jpgTri Axis install 001.jpgTri Axis install 002.jpgTri Axis install 015.jpg
    Jul 2014
    United States
    At what mileage are you going to replace them? And, what about changing out the airbox to the custom one at the same time? Someone posted some time ago that changing the box gave much more access to the engine. That would probably include the plugs.
    Jun 2011
    Near Lexington, NC
    Iridium plugs run over a 100K miles in a car, many of which run RPM's as high as the 1330. Personally, I don't plan to change mine unless I can see/feel a change in performance. Maybe if I were to do long hauling like Anne and some others, it would be
    worth doing. But for many of us, give it 40 or 50K at least.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Sep 2013
    N. Va
    Your plugs in your 2014 should be good for a LONG time. You may not get to 100K mi, but you will be close. Watch your mileage, and you will see when you need to do a tune up.
    You will be much happier for not doing a plug change now.
    Jerry
    Sep 2014
    3rd ROCK FROM THE SUN !
    anyone know what the owner's manual recommends for changing spark plugs in a 2014 RT with an ACE 1330 engine ? can't seem to find my manual at the moment ?
    osm
    Oct 2007
    Quote Originally Posted by Orange Spyder Man View Post
    osm
    28000 miles
    Jun 2010
    Las Vegas
    Quote Originally Posted by Doc - Riverside View Post
    That's what I figured. Nothing is easy on the Spyder
    Quote Originally Posted by Doc Humphreys View Post
    On the 2014 the air filter is round (think oil filter shaped) and is relatively easy to change. I don't see where you would gain much more access on the 1330 by doing that.
    I think we will wait a while. I'm at 34,600 miles and like someone else pointed out the manual says change at 28,000. I'm not having any issues but was just trying to follow the guidelines for a change!
    2010 RT- 622
    Sep 2013
    N. Va
    You have 34,600 miles on your 2014!!?
    Sep 2014
    Quote Originally Posted by ACE1330 View Post
    28000 miles
    gee thanks... I have some time before changing them will be necessary.. I don't have 1000 miles on my Spyder yet..
    osm
    Jun 2010
    Las Vegas
    Quote Originally Posted by spacetiger View Post
    I do, I picked it up on 02/21/14. I've been slacking since October though.
    2010 RT- 622
    Jun 2010
    Las Vegas
    Quote Originally Posted by Gray Ghost View Post
    It is especially bad this year, at least in the past it told you what panels you needed to remove. This year the spark plug section looks like an afterthought.
    2010 RT- 622
    Default FRUNK REMOVAL
    Ann I just read your latest post and you arn't going to do your plugs for awhile so this won't affect you NOW.........However for those that are contemplating this ...I just removed mine !!!!!,,,,I watched Three video's above doing this ( got a headache from all the motion ) ( and the Aussie one I could barely hear )........and maybe this will HELP.....The only TOOL you need is a 10 mm socket....if you have a wobbly and an extension and a drill adapter it will go faster........this was never completely explained BUT underneath the Spyder they show you two bolts and two nuts on the cross piece.....you only undo the 10 mm bolts ...leave the 12mm nuts alone .............on the top after you remove the plastic triangular pieces you will see 6 bolts , they all 10 mm ....the two in the middle leave them alone ......just undo the outside one's (4)................I have a BASIC RT so the only two plugs were on the left as I faced the Spyder ,if you have FOG lights etc there are more plugs to detach......In none of the Video's was the AIR SCOOP mentioned ( it's under the left front fender ) ( right side as you face it )...............well they should have because that was a B*tch to undo, have one or two small screw drivers handy , you will need to loosen the clamp and pry off the rubber ELBOE.....at least that's what I did........I may not put it back on..............Have fun ....Mike
    Jul 2014
    United States
    That is rolling some rubber! Wow!
    Jun 2010
    Las Vegas
    You did this for the heck of it? You may be a little crazy. We will give it a go but maybe next month. Did you have to take off the fairing (glove box, dash) or just the front trunk and the left and right acoustic panels?
    2010 RT- 622
    Nov 2012
    North Las Vegas, NV
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Sep 2013
    Harper, Texas
    I had to check the page numbers three times. I was convinced that some pages didn't get scanned. Lots of luck when y'all attempt it.
