Congratulations..!!
looks great. The dash is awesome and always liked the grilles. But winter is not over..what else..??
2012 RS sm5
Looks very nice
Did you use OEM paint on the dash or did you find some other paint that matched
I want to do dash and rear fender
Thanks
Don
Now 2014 RT Limited Cognac
Was 2008 GS SM5
Don Garbarino
Cup Holder
GPS locking holder
Mud flap
Modified KNOTT grill
Phone holder and charger
Trailer hitch
Dual air horn
Auxiliary fuse box with relays
Heated clothing controller
volt/oil pressure gauge
Sequential signals in mirror
Tri Axis Handle bars
Baja Ron anti sway bar/heim links
shorty antenna
And many more
Thanks
Don
I used VHT High Temperature Engine Metallic Drive Train Paint Chemical Resistant Coating. Sent a pm Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
Thanks
Don
VHT high temperature Engine Metallic SP402 Burnt Copper + Clear Coat
YESSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS SSSSSSSSSSSSSSSSSSSSSSSS
....Since you have used this Paint and seen it close up and personal , do you agree that it is EXTREMELY close to the OEM Cognac color.........The only thing I did different was to keep the area directly around the instrument cluster FLAT BLACK, to prevent any glare possibilities..........I found this paint awhile back and used it on my RSS ( after buffing the shine out ).....I then convinced DEE that with a few coats of CLEAR in would deepin the shine effect............I think it really makes the Dash surround POP..................Nice job.........Mike
[QUOTE=BLUEKNIGHT911;930520]
The color match is spot on! At $15 a can how can you go wrong!
I thought about leaving the part closest to the gauges black as well, after the first couple coats.
I like the look I have though and if glare becomes a problem it will be an easy enough fix.[/QUOTE....................... Only $ 8.50 here, but if you actually used BRP paint it would have been $ 50 + at least..............glad you liked it ,,,,,,Mike
$8.50 USD, that's just short of $100 CAN!
Thanks you, thank you, thank you, Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
You inspired me! That dash really pops! I ordered the paint to do mine.
2014 Cognac RT-S SE6 "Rusty"
Had a chance to do a little Farkleing!
Have to thank Deanna777 for the inspiration for Farkle #1
Painted my Dashboard Bezel
Had a chance to put on my Spyderpops Stainless Grilles & KOTT Grilles rohana wheels
I'd also like to give a shoutout and to Finless Bob for his video on replacing the Spyder Speakers, probably saved me a week!
And this little stance wheels gem is a pic of just how far you have to go to replace the saddlebag cargo module, I don't recommend this!!! (rear speaker not part of this tear down) tsw wheels
NICE WORK!!
