2014 RT Limited can't raise seat
Just tried to raise seat and key switch does not turn in gas direction thus cannot raise seat. Had at dealer last fall for same issue and it worked fine until now. Anyone having this problem and know fix?
You might try pushing down on the seat as you turn the key. you may have to adjust the length of the bolt to lock the seat.
2014 RT Limited Cognac ----- Wraps, skid plate, lights, Elkas
2002 harley ultra classic
2008 hayabusa
NO BIKE AT THIS TIME
Same happened to me recently
My seat would not lift the other day, I used a coat hanger straightened out with a small hook on one end, pass it through the gap between the seat and the Tupperware and hook it open, I could not get it to work with the key even after I opened it with the coat hanger. I got mine open and then did what was suggested here, I put a small length of fishing line trace on to the latch and tucked it up into the void on the right hand side of the seat. I took it to the dealer and he said the cable had been run the wrong way during the assembly and re-routed it.
Pjb_Brisie
The cable froze up on ours over last winter but I was able to free it up with WD40 after dismantling most of the area around the ignition switch. I also put a wire from the latch to just under the seat at the right front in case it happens again.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
[QUOTE=pjb_Brisie;929329]My seat would not lift the other day, I used a coat hanger straightened out with a small hook on one end, pass it through the gap between the seat and the Tupperware and hook it open, I could not get it to work with the key even after I opened it with the coat hanger. I got mine open and then did what was suggested here, I put a small length of fishing line trace on to the latch and tucked it up into the void on the right hand side of the seat. I took it to the dealer and he said the cable had been run the wrong way during the assembly and re-routed it.
I will try the coat hanger method when it gets a little warmer. Thanks for the help
Have the same issue with mine, to fix it when needing to lift the seat before I turn the key I grab the front of the seat and with slight pressure lift upwards. The seat seems to release then I turn the key, the seat lifts every time.
