Results 1 to 14 of 14
    May 2014
    Mt.Pearl,Newfoundland,Canada
    Question PAIN IN THE NECK
    Does anyone have a 2014 spyder rt with stock handle bars, and having a neck problem, when I ride for about 30 to 50 kl I get a real pain in the neck, its been suggested that it could be the handle bars,any suggestions would be appreciated, THANKS, Winse.
    Active Member snics's Avatar
    Chelsea, Quebec, Canada
    Default yep
    Bought the tri-axis handle bar and it helps some.
    Relaxing he grip seems to help some for me.
    May 2014
    Default Thank you.....
    Quote Originally Posted by snics View Post
    Thank you..
    Default Position...
    handlebars don't affect your neck as much as your ryding position. Windsheild type and deflection, helmet, seating, backrest etc cause you to use your neck more or less causing some folks problems. But many have gotten help by changing to different bars because it helps change their posture.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Sep 2012
    Junction City, KS, USA
    Before I got the tri-axis bars, I had shoulder pain from the wide grips. Keeping a looser grip also might help. If you're tensing up in general your neck may be taking the worst of it.
    PrairieSpyder (Patti)
    Jun 2010
    Las Vegas
    +1 on the shoulder pain and mine was fixed by adding the TriAxis bars.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Active Member 3 Wheel Rider's Avatar
    Jan 2015
    San Antonio, Texas
    The wide grip on the stock bars caused arm, back, shoulder and neck pain. the Tri Axis Handlebars and a drivers backrest eliminated the discomfort.
    2014 Spyder RT Limited SE6
    BRP Tri Axis Adjustable Handlebars
    BRP Adjustable Wind Deflectors
    BRP RT Passenger Armrest
    BRP Driver's Backrest
    BRP Travel Cover
    Baja Ron Swaybar
    SpyderPops KOTTS
    SpyderPops Bump Skid
    Lamonster NVB Highway Brackets w/ Gripper Pegs
    Lamonster LED Headlights & Fog Lights
    Custom Dynamics HMT Brake Light
    Show Chrome 7.5 inch Spiral Antenna
    SpyderFlap Mud Guard
    Helmetlok w/ T-Bar Extension
    Hopnel 5PC Luggage Set
    Airhawk R Seat Cushion
    Rivco Dual Flag Mount
    Another possibility is to change your seating position a bit. A sheepskin or AirHawk seat pad will raise you up a bit so you are not stretching as much to get to the handlebars.
    A slightly less costly fix than the tri axis. You will have many more adjustment options with the tri axis though.
    Registered Users SpydrRydr's Avatar
    Oct 2013
    Okanagan BC
    Default No Issues!!
    Quote Originally Posted by Winse View Post
    I am 5'4" and have no issues but ride with a back rest which is really nice. I thought I wouldn't need it but find I like the back support. It likely helps with slouching which might contribute to your problem. Also relax, the Spyder will track the road nicely....no need to oversteer.
    Northern Kalifornia
    Default Had the same thing
    Lots of good suggestions here but as time goes by and the miles add up, the neck pain will go away. I think it all has to do with becoming accustom to riding that new horse you bought. I've got over 5K now and I don't notice anymore pain until I've been riding for several hours, like a full tank's worth. It'll go away in time.
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Get a Throttle Rocker
    Apr 2015
    Blythewood sc
    Tri-axis and backrest makes riding more comfortable. Now to fix the aching tailbone problem.
    Invalid Emails
    Oct 2015
    Deland, FL
    I put on a backrest within a month of getting my 13 RT Ltd. helped somewhat and then played with adjustment and found that moving it to a higher position and more forward so I'm not leaning back. Also, in the twitters I find that if I pull with the side closer to me on the bars and just use the other hand as a guide helps because you're not always stretching out so much. And remember to use a light grip. The bike steers really easy.
    Quote Originally Posted by derrill View Post
    See post #8
