Page 1 of 2 12 LastLast
Results 1 to 25 of 26
    Very Active Member bluestratos's Avatar
    Jun 2011
    Lynden, WA
    Default Any one find good quality LED bulbs to work in the RT Headlights
    It appears that there are LED bulbs that work in projector style headlights on the market now, any one try any yet?
    Default LED's
    SpyderAnn01 mentioned she was going to be putting them in Hers ......But when asked for for further info ...............none given............Good luck, others here are interested also...............Mike
    Jun 2011
    Lynden, WA
    I will let you know :-)
    Mar 2013
    South East Wisconsin
    Default I am interested as well and
    Quote Originally Posted by bluestratos View Post
    will be following this thread..
    Lets ride!!!!
    Jun 2010
    Las Vegas
    We have been very busy working on other people's Spyders and mine has been left unrepaired. I'm hoping that next week my Spyder will get a turn and I'll get the LEDs installed.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Very Active Member Papa's Avatar
    Aug 2010
    Mundelein IL
    KBCarStuff.com is a vendor on this site. I had their LED's on my 2010 RT and have them on my 2014 RTS. Ignore the pun but he difference is night and day.
    Illinois Patriot Guard
    Founding member of Woodstock Spyder Ryders
    2014 RTS SE6 - White
    2010 RT/AC SE5 retired with 26,536 miles
    Mar 2013
    Default Can you please expand
    Quote Originally Posted by Papa View Post
    your experience with the LED's. Part number used, installation experience, difference in nighttime driving etc. Thanks!
    Lets ride!!!!
    Aug 2010
    Mundelein IL
    The bulbs I ordered were : 9005 / HB3 4300k Xtreme Xenon HID . The wiring harness that comes with DOES NOT have to be installed when using these on a Spyder.
    The stock lights are more of a yellow color, theses are a bright white and cover a larger arc of light. Since the Spyder uses a lens to go from normal to bright light the only effect is the light shines higher, same as the stock lights.
    All I can say about the experience is that if I didn't have them I would avoid riding at night. We have deer in the area and riding the country wooded roads at night would simply be to dangerous. The LED's make a enormous difference.
    Very Active Member bruiser's Avatar
    Eastern North Carolina
    HID and LED are vastly different bulbs. Check wiredux, supporting vendor, he has LED headlight bulbs available.
    USAF '69-'89 E7
    Thailand/Vietnam 1972
    Default YESSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS SSSSSSSSSSSSSSSSSSSSSSSS
    Quote Originally Posted by bruiser View Post
    .............Thanks Bruiser, ...welcome back............and yes HID and LED is a whole different thing ...............Mike...................................I just checked the site , the only LED Headlite bulbs He had were for ..H-11.........That won't work for my RT.....
    Default LED's
    Quote Originally Posted by SpyderAnn01 View Post
    ..........Thanks Ann, waiting to here your opinion ..............Mike
    Jun 2011
    Lynden, WA
    Well I tried the 80 watt LEDs and no go, they put out less light than the stock bulbs, nice and white but not as bright. Also, they are too long for the dust cover on the back of the headlight assembly. If you leave it off or cut the cover the fan in the LED would push dust into the headlight area.
    But.. I tried rewiring my HID's and fixed the problem, no more strobing and going out. I had run them for 6 months via my fuse panel that is powered off of a accessory line with no problems but a few weeks back they started acting up. Today I ran the power to the HID relay directly from the battery and it fixed the problem. My hunch is that I was drawing too much power over all.
    Invalid Emails
    Aug 2010
    Guelph,Ontario,Canada
    Default H11 HID BULB ?
    Quote Originally Posted by garb55 View Post
    H-11 and 9005 are the same
    For halogen the H-1 and 9005 are different because one is more wattage than the other
    I put H-11 Hid bulbs in my 2014 RT limited
    The LED bulb itself is cooler [temperature] than other bulbs but it has a heat sink in back of it that gets very hot
    Since the bulb in the Spyder is enclosed in a housing I did not know what that heat would do
    Don
    I just went KB Car Stuff and looked your H11 HID Bulbs that you put in your spyder.
    The ones I found http://www.xenondepot.com/H11-HID-Ki.../xt-h11-rb.htm
    So I am a bit confused because the only bulb that I could find is a replacement for the bulb used in their HID KIT not just for replacing spyder halogen headlight bulbs. I would need the HID Kit to be able to use this bulb
    Can you please post some more info on the bulb you used and include a link too please thanks.. Mark
    Aug 2010
    Cloquet Mn
    Default LED 9005
    Just received these in the mail, when the garage warms up I will put them in.
    http://www.superbrightleds.com/morei...kit/2117/4802/
    Default THESE LED's
    Quote Originally Posted by bobbobtar View Post
    I'm curious what you are putting these in/on..........I have a 2014 RT, and according the Owner's manual that came with the Spyder the Headlights are .....H-4 .....So now I'm thoroughly confused as to what type bulbs are correct ?????????..................Mike
    Aug 2010
    Cloquet Mn
    I'm cutious what you putting these in/on..........I have a 2014 RT, and according the Owner's manual that came with the Spyder the Headlights are .....H-4 .....So now I'm thoroughly confused as to what type bulbs are correct ?????????..................Mike
    I have a 2014 RT-S the headlights are 9005 maybe you were looking at the fog lights, if it doesn't work out I will use them on my Chevy 2500HD
    Invalid Emails
    Aug 2010
    I used the H-11 HID kit from Xenondepot
    What I was trying to explain in my earlier post was the bulb will fit in the Spyder RT
    The 9005 and the H-11 use the same housing but the HID bulbs need the kit to start with
    Hope that makes sense
    Don
    Thanks Don that makes sense now
    Default H-4 HEADLIGHTS ?????
    .............No I have an RT basic ( no fog lites )....The manual only lists HEADLIGHTS 2 X 60w...Halogen ( H-4 )....................Mike
    SoFlo
    FWIW, the general consensus in truck / automotive forums is that the current aftermarket LED headlight bulbs are not powerful enough to serve as a vision upgrade. Many look good for show. LED technology is still not at the limit yet.
    PK
    Sep 2013
    Houston
    I can already tell you that you will not be happy with those in the spyder. The LED element faces the wrong way for a projector beam headlamp assembly. That is the problem with every one of them I have seen so far. None of the mfgs. have come up with some designed for projector beam style lamps. The LED needs to face forward, not to the side.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Sep 2013
    Houston
    Then the manual is wrong. Not the first time. Could be a carryover from the old GS lamps.
    Active Member kyspyder's Avatar
    Aug 2007
    Shelbyville, KY
    Here are the "best" LEDs currently available,(when in stock)
    http://www.vleds.com/led-headlights/9005.html
    They work FANTASTIC!
    kyspyder
    Jun 2011
    Lynden, WA
    Will these fit inside the dust cover on the back of the headlight assembly? They about the same lenght as the ones I bought which will not work.
    Quote Originally Posted by kyspyder View Post
    kyspyder
    Registered Users mtdoragary's Avatar
    Jul 2010
    KILLEN, AL
    ... and HID's are a LOT less expensive!
    3:16
    Very Active Member retread's Avatar
    May 2008
    Bargersville, IN
    I understand that the new H-D Road Glide uses led headlamps, maybe a trip to the local dealer would give an idea of what they're using.
    john
