Results 1 to 21 of 21
    Jul 2014
    United States
    Default New Rack Coming Along Nicely
    Mock up of the new Roadster Renovations rack. It looks pretty sweet, even unpainted. Dimensions are 36x15x4. Total rack weight around 10 lbs. That leaves 30 lbs. for goodies!
    Very Active Member Big Arm's Avatar
    Jul 2008
    Sioux City, Iowa and Tucson, AZ
    Nice job of fabricating
    ....and we're gonna ride, we're gonna ride.....
    ride like the one-eyed Jack of Diamonds, with
    the devil close behind,.....we're gonna ride....
    2008 GS.....PE # 2888
    Jun 2013
    queens ny
    looks great, is it going to be removable or permanent
    NO BIKE AT THIS TIME
    Oct 2014
    Jefferson City, TN
    NICE RACK!!
    (sorry...I couldn't resist!)
    Gene
    2015 Honda Goldwing Comfort/Audio
    **SOLD**2014 RT Limited, Black Currant
    B
    1975 Yamaha RD-125, Red
    1500 miles, all stock time capsule!
    Sep 2014
    mathias,wv
    Default rack
    Looking very good Doc.
    Are you going to paint them or powdercoat them?
    If you were closer I could help you with the powdercoating.
    What is next from the "Fab" shop?
    [SIGPIC]
    Default Congrats..!!
    progressing nicely and the finished product will be a looker...
    ​2012 RS sm5
    Very Active Member ahh-cool's Avatar
    Jun 2014
    south florida
    Quote Originally Posted by Doc Humphreys View Post
    Doc I also made a rack similar to yours. The problem with the placement is it's too far forward. When my rear shock bottomed out I broke the plastic under the license plate.
    Stefan
    Very Active Member WA5VHU's Avatar
    Cooper, TX
    Default Clear the Ball?
    Looks nice, will it clear the hitch ball if left on?
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default mud
    a nice BIG MUD FLAP will be needed....
    very nice job... cheers....
    Dan P
    SPYD3R
    Very Active Member GunDoctor's Avatar
    Sep 2014
    Los Angeles
    Really nice.
    Another Day To Be My Kid's Dad [emoji379]
    2015 F3-S. And Another Day To Be My Kids Dad
    Jul 2014
    United States
    Quote Originally Posted by cuznjohn View Post
    It will be able to be unbolted. It is secured on 3 points and on and off in 5 minutes with a couple of hand tools.
    Jul 2014
    United States
    Quote Originally Posted by WA5VHU View Post
    Hitch ball will need to be removed. The main attaching bolt will go through the ball hole. We might make a version using a different connection method if there was enough response for it.
    Jul 2014
    United States
    Quote Originally Posted by SPYD3R View Post
    Dan P
    SPYD3R
    We may sell a companion waterproof bag of the same size that will attach to the rack. The rack doesn't extend past the side cases, so some natural protection will be there. In wet weather, something will be needing done. What we have done with the larger model is to put the more fragile items in the bike's cases, and our clothing and such on the rack. Able to carry much more stuff without dragging a trailer!
    Jul 2014
    United States
    Quote Originally Posted by ahh-cool View Post
    Stefan
    Don't know if you can see the offset by the tire, but the final positioning will avoid the fender area entirely. That is a substantial travel for the suspension going up. I will watch for the travel and positioning! Thanks for the heads up!
    Dec 2014
    Central, Florida
    Default Available?
    Is this rack available? if so, how much?
    Apr 2011
    GREENVILLE, SC
    Default HARBOR FREIGHT
    Doc, you may want look at some of the CARGO CARRIERS that HARBOR FREIGHT has to offer...
    may save you a bunch of time from building new... one may be adapted to your requirements...
    http://www.harborfreight.com/automot...cle/cargo.html
    Dan P
    SPYD3R
    Jul 2014
    United States
    Dan P
    SPYD3R
    The one I had on my bike at Spyder in the Smokies was from Harbor Freight. It is 48" wide by about 20". I heavily modified it to make it manageable. It still is too wide for me and in order to reduce it further would require even more modification. I also have the aluminum model I use on our little Geo Tracker and was very disappointed that it uses plastic corners. Evidently, they thought that would be strong enough for most applications. I don't think so and I would never sell something to someone so poorly (in my opinion) made.
    This unit we are creating will be steel, yet very light, strong with few seams. Something that will last for years, look sharp, fit the size of the bike and side cases.
    The base model will probably run around $200 and the best with all the bells and whistles could run as much as $400.
    I will be making 5 prototypes that we will be offering in the near future for testing. Please PM me if you would like to be one of the 5. We will give a discount for the first 5 testors.
    Jun 2014
    south florida
    Dan P
    SPYD3R
    That's what I did. I took the aluminum rack and cut it down. The weight of the Rack is about 6 pounds and the box weighs around 3 pounds. Then welded the seams and put it on the bike with a 3 point attachment.
    The box is a "Really useful Box" brand that they sell at office depot. Strong enough to put a car on it.
    The third pix is where I had to put stiffeners to the ball mount because it was bending.
    Jul 2014
    United States
    wow! If you go if for any warranty repair I would remove the hitch beforehand. Otherwise, if it's noticed what happened, they may give you grief.
    Active Member purplepig's Avatar
    Sep 2011
    webster,ny
    Default fyi
    A couple of pics of how I did it. Works great so far. About 1500 miles with about a total of 20 pounds on it. The rack and mount are made by Kuryakyn.
    Bossier LoUiSiAna
    Not going to have to relocate plate? Small flat box instead of cooler ? Good thing it's on a Spyder not a Harley! Still looking for the redneck gun rack on one.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
