Results 1 to 6 of 6
    Slidell, LA
    Default Wind shield tint
    Thinking about tinting my wind shield black. Anyone think there's a legal issue with that here in LOUISIANA?
    Bryant, Arkansas
    Quote Originally Posted by Cajun View Post
    If you look through your windshield .................... It will be a problem at night no matter what state you are in.
    If you put info in about which Spyder you have (year and model) most folks on here can give you better advice/suggestions because several of these bikes are completely different and what works on one may not work on another.
    Cruzr Joe
    Default Depends..!
    Like mentioned above the size of the shield will determine that in many states. If it is more of a deflector should not be a problem but if you see throught it it can be. You can use the peel and stick type and remove it if you have to...
    Slidell, LA
    Default Thanks
    Thanks for the info guys. Its a 2013 ST. When riding if pretty much look over it. It's adjustable up and down though so I've got to be careful with it. Yes, for sure peel and stick window tint is what I'm planning.
    Thanks for the input.
    Bossier LoUiSiAna
    Default Tint?
    Ive done decals out of line of sight but no need for tint
    Jan 2013
    greenville, sc
    I look over my windshield not through it
