Looking for tech answers
Howdy.
I recently picked up my 2010 RT from my local dealer after it was serviced.
As a result, I am seeking answers from the great people of SL to give me confidence that my dealer did things right.
So...here goes: WHAT IS A "TPS SENSOR?"
The dealer found the following codes: P1120, TPS sensor out of position.
P2620, TPS
C1290, VCM Voltage Failure -- need to replace TPS
sensor.
How many TPS sensors are on the RT?
Why would a TPS sensor be "out of position?"
Would the VCM Voltage Failure require replacing the battery? It was only a year old.
I need, and appreciate, all the help I can get.
Thanks,
JOHN
Test message.
2016 Spyder RT
TPS is throttle position sensor . . . don't know about the rest . . .
"Topper" is my Pearl White 2013 RT-LTD
Professional Retiree - liked it so much when I retired from the USAF, that I started another career so I could do it again!
Happy to be a member of the Maryland Spyder Web - find us at
http://www.meetup.com/MarylandSpyderWeb/
Well..!!
Our own Roger Rattigan has a program (app) for you. Will explain all this stuff. TPS (throttle position sensor) TAS (throttle acceleration sensor) VCM (vehicle control module) but none will require replacing the battery unless it itself is faulty. The biggest load on your battery is the DPS (dynamic power steering.. App for android is spyder codes and for apple is my spyder...
2012 RS sm5
I just watching to see the answers.
Cruzr Joe
Having not personally attended the BRP Tech Program but am well aware of position sensors on hi tech-planes, I can offer this opinion..... a bad sensor can cause faulty error messages for other systems provided those systems rely on that sensor as an input. In essence, bad input equals bad results.
My 2-cents, Replace or Adjust the TPS and clear the codes and wait to see what repeat codes you get.
Hope this helps!
SpyderLovers Founder
Originally Posted by Air Force PAO
Howdy.
P2620, TPS
sensor.
Thanks,
JOHN
You could have a bad TPS or you could just have a throttle body that needs cleaning. I had this happen to me on my 2010 in Sturgis. I was able to break the throttle plates free and reset the the TPS with buds. This is something you need your dealer to look at.
Voltage is also very critical on the Spyder, love voltage can throw unrelated codes too.
So...here goes: 1. WHAT IS A "TPS SENSOR?" ... 2. How many TPS sensors are on the RT?
3. Why would a TPS sensor be "out of position?"
From my 2013 Manual:
1. "THROTTLE POSITION SENSOR (TPS)
General: The throttle position sensor (TPS) is a twin potentiometer that sends two signals to the ECM, that are proportional to the throttle shaft angle."
"The TAS (Throttle Accelerator Sensor), CPS (Crankshaft Position Sensor), the MAPS (Manifold Absolute Pressure Sensor), and the TPS (Throttle Position Sensor), are the primary sensors used to control the injection. Other sensors such as temperature sensors are used as secondary inputs."
"An electric throttle actuator (ETA) is used to control air delivery by opening or closing the throttle plates. It allows the ECM to electrically control the position of the throttle plates throughout the full range of engine operation.
The TPS provides the ECM with a signal of the actual angle position of the throttle plates. When the ETA changes the position of the throttle plates, the ECM uses the TPS signal to monitor the throttle plate position, and modulate the ETA through pulse width modulation to move the throttle plates until the targeted position of the throttle plates is achieved."
2. There is one TPS
3. "THROTTLE POSITION SENSOR RESET
General Information
This operation performs a reset of the values stored in the ECM for the TPS when it is at the closed position and at the limp home position. The TPS position is used to determine the basic parameters for all fuel mapping and several ECM calculations. A reset must be carried out each time any of the following situations has occurred:
– Throttle position sensor (TPS) has been loosened, removed, or replaced.
– Throttle body has been replaced.
– ECM has been replaced."
The reset procedure is done with the BRP Diagnostic Software (BUDS). Possible problems with the TPS are connector loose/disconnected, sensor loose, sensor damaged or corroded, wiring problems, or sensor worn.
That would require troubleshooting. It is possible that a year old battery can be bad, or it might be something else. If a battery was not prepped properly before installation it could very easily have a short life span.
Clifford Fargason
2013 Spyder RTL
2007 Royal Star Venture
Tech answers
Terrific.
Thank you all very much. I feel very good that the information shared is on target and does well to answer my questions.
Looking forward to ryding.
JOHN
Test message.
2016 Spyder RT
