Results 1 to 18 of 18
    Apr 2011
    GREENVILLE, SC
    Default OIL CHANGE - upgraded to full synthetic!
    FINALLY upgraded to FULL SYNTHETIC OIL....
    i did an oil change today on my F3S, SE6... it now has FULL SYNTHETIC VALVOLINE 4T oil...
    took her for a short ride, and i was surprised at just how smoooooth the shifting is now - WOW...! ! ! i love it...
    i've always used the BRP blended oil in both my RS and F3... my dealer charges $13 per qt, and the VALVOLINE was $6.67 at Walmarts... no brainer, i'd say...
    WALMARTS: https://www.walmart.com/ip/Valvoline...Quart/16777818
    NOTE: the old oil had 9028 miles of smiles on it, and it truly looked golden... just a few shades off from new... i wouldn't recommend anyone going past the 9200 mile mark just because of the color... this is only a 'statement' of what it looked like...
    however, i do recommend the VALVOLINE oil to any and all...
    Dan P
    SPYD3R
    Default FULL SYN OIL
    ......... Glad you finally got onboard .....I've been Hyping the .. 4T ... for a couple of years now ...... Mike
    Default Congrats....
    Good choice you will be happy with it...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Mar 2018
    ca
    Default Too late
    Damm already paid 79 for the dealer suggested oil change kit. Next time
    Gonna try the vavoline
    Phil bakersfield
    Default 4 T oil
    Quote Originally Posted by Philrs View Post
    Phil bakersfield
    You won't be disappointed ....switching to Full Syn is the way to go ...... this Valvoline has the second lowest amount of Molybdenum ( which is bad for a wet clutch ) in the full syn industry....the lowest is Amsoil, but it costs quite a bit more .... Mike
    Apr 2011
    GREENVILLE, SC
    Default WOW..!
    WOW, i'm here to tell you that SYNTHETIC OIL makes a world of difference....
    I just got in from a short ride, 81 miles of smiles, and that new VALVOLINE FULL SYNTHETIC oil makes for much smoother shifting, and the engines seems to run smoother and quiets down by 10 decibels...
    i'm sold on this oil....
    just thought y'all would like to know....
    Dan P
    SPYD3R
    Very Active Member ofdave's Avatar
    Jul 2017
    sarasota, fl
    thanks for the update
    have been thinking about the Valvoline and have used it in other bikes.
    Now I know, and my oil change coming up will be done with the Valvoline.
    Already have the filter kit from Bajaron.
    2017 F3, SM6-basic black, plain and simple
    INDIANA, USA
    Default Oil Change
    Thanks For the INFO. Next Time Valvoline will be my 'OIL of Choice'. A question for you, How big of a Job was THIS? Time?
    ENJOY YOUR LIFE WITH A SPYDER
    Apr 2011
    GREENVILLE, SC
    Default NOT BAD
    Quote Originally Posted by Little Blue View Post
    NOT a bad job... more like FUN...
    took me less than 1 hour, but i mess around during the process...
    you'll need to get your ride off the floor for easy access to the underside...
    keep in mind there are 2 drain plugs 1 on either side of the engine...
    these are the tools you'll need to perform the Oil Change:
    from top left - bottom right:
    lights are essential, i use a 'stand up' and a 'hand held'...
    a torque wrench...
    a cup to hold screws & push pins...
    a TORX T25 to remove screws of the right side panel... mine is in a power driver...
    a 17mm open end wrench for the drain plug on the right side (i hope you have GOLD PLUGS, otherwise you'll need TROX)...
    a small screw driver to help remove old O rings...
    a 3" & 6" 3/8 drive extensions, with a 14mm socket for left side plug, again GOLD PLUGS... and a ratchet wrench...
    Channel Locks to remove the oil filter cap... be careful here, the cap has an very thin extension that goes down the middle of the filter and if forced, it could break... you'll need to hold the old filter up inside the cap for easy removal of this assembly...
    a push pin extractor...
    hope this helps, and good luck...
    Dan P
    SPYD3R
    INDIANA, USA
    Default Oil Change
    Thank You for you quick reply. The INFO was just what I needed, Guess I need to buy a lift.
    Apr 2011
    GREENVILLE, SC
    Default RAMPS
    i use RAMPS.....
    Harbor Freight: https://www.harborfreight.com/catalo...nk%2Cf&q=ramps
    Dan P
    SPYD3R
    Active Member TRBorslien's Avatar
    Mar 2018
    West Fargo, ND
    Newbie question.
    I was considering buying a Harbor Freight lift to adjust front shocks. Can the lift also be used for an oil change on a 2012 RT? Maybe in conjunction with jackstands?
    Thanks!
    Tony
    2012 RT-S SE5 - Viper Red
    Castle Atom SV Tarmac Modular Helmets
    Sena SMH5 Headsets
    Ultraguard Half Cover
    Hopnel Luggage: Frunk, Top Case, and Saddlebags
    Big Bike Parts Short Spiral Antenna
    Kumho Ecsta AST 225/50R15 Rear Tire - Got almost 18,000 miles before replacement with Riken Raptor
    Vredestein Quatrac 5 165/65R-14 Front Tires
    BajaRon Spark Plugs and Wires
    EBC Rear Pads and Rotor from BajaRon
    Riken Raptor HR 215/60-15 Rear Tire
    Future Plans:
    2013 Cooling Kit
    BajaRon Sway Bar
    High-Mount Brake Light
    2012 RT-S , Viper Red
    Apr 2011
    GREENVILLE, SC
    Default YES
    Quote Originally Posted by TRBorslien View Post
    Newbie question.
    Thanks!
    YES....
    however, the HF lift tends to get in the way of accessing the drain plugs and eliminates a drain pan of any size... however, it is possible, but can be pretty messy... if you use the 'lift' & jack stands, place the jack stands under the A-arms, then remove the lift... this will make life much easier for you....
    PS; put a rag or some rubber between the jack stand contact points and the A-arms... otherwise, you may scratch the paint on the A-arms...
    Dan P
    SPYD3R
    Feb 2012
    Spring City,Utah
    the Harbour Freight ATV lift works just fine. If you get it in the right place it will balance the Spyder. Jack the suspension all the way up to get it under the spyder.My lift also has a lock on it that blocks it from sinking down. I also run a strap over the seat to tie it so it wont slip.
    I also use a pair + 1 of ramps. I run the spyder up on two then jack the rear end up and put a 3rd under the rear wheel. That is a lot cheaper then the HF jack and has become my prefered method of lifting.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Phoenix
    [QUOTE=SPYD3R;1351171]NOT a bad job... more like FUN...
    a torque wrench...
    Dan P
    Is this the correct size for the drain plugs...when you swap them out to the gold plugs...same size? do the o rings come with the gold plugs?
    https://goldplug.com/shop/mp18/
    Apr 2011
    GREENVILLE, SC
    Default YES & YES
    [QUOTE=marty1096;1351290]
    Quote Originally Posted by SPYD3R View Post
    a torque wrench...
    Dan P
    Is this the correct size for the drain plugs. when you swap them out to the gold plugs...same size? YES do the o rings come with the gold plugs? YES, if i remember correctly, they do come with the O Rings....
    YES & YES.......
    INDIANA, USA
    Default Gold Plug
    The referenced Web Site Says, 'must reuse your stock/o-rings'. Did not see anything about THEM offering to sell the necessary o-rings. The Aluminum washer is included with the Plug (MP-18).
    Default Gold plug rubber washers
    I've done three oil changes with the same orig. OEM washers I put on my Gold Plugs .........no leaks ......... if it isn't broken I don't fix it ..... Mike
