Results 1 to 12 of 12
    Dec 2014
    springville, Alabama
    Default ST Handlebars causing shoulder ache
    After riding for about an hour my shoulders begin to ache. I can't find where the 13 ST Limited has a riser option. My arms are a little short for a a comfortable ride. Welcome suggestions.
    Very Active Member Don in E Texas's Avatar
    Feb 2009
    Gilmer, TX
    Default Sitting position is sport.
    ...so most folks have to lean into the bars. I did not care for it and rode my '08 less and less each year. My RT solved all those issues (and more). Maybe a check of our vendors would be helpful? Or someone with the same model bike will be helpful and make a post.
    Anyhow....welcome to the board!!
    don
    Did own: 2008, Red, SE5 - and 2010, Black, RT-S Premiere Edition Number 670
    Now Own: 2014 Black RT-S SE6
    western Colorado
    Quote Originally Posted by Cole Younger View Post
    You might try sitting closer to the bars instead of back. Or a different seat maybe in order.
    Active Member Dgjason's Avatar
    Jul 2014
    Old River Winfree Texas
    Cole, I also have a 2013 ST Limited. I am 5-8 1/2 and the first purchase I made was a Ultimate Seat. I have rode for over 4 hours straight with no problem. I use to get shoulder and back pain when riding my two wheel motorcycle. I was worried that I would experience the same problem and was certainly relieved that the back and shoulder problems have not returned.
    2013 ST Limited
    Very Active Member 900Dave's Avatar
    Jun 2013
    Fleetwood, PA
    The Ultimate seat "low rider" will move you 2 inches closer to the bars OR you can bolt on a set of RT bars. That will put the bars closer to the seat. I would go with the new seat.
    2016 Spyder F3 Limited Steel Black Metallic
    Lamonster approved LED Headlights
    Lamonsters LED Fog lights
    BRP Driver & Passenger backrest
    BRP Trailer Hitch
    Shamrock Black & Polished
    Signature light
    Elka front shock's
    Rolo Laser Alignment
    Dual Power outlets
    Garmin 590 GPS
    It's more of a seating issue, than a handlebar issue.
    Mar 2013
    I had the same issue with our ST and I purchased the BRP adjustable handlebars. BRP dosen't say that they will fit an ST so I was going to make it last winters project to get them to fit. I solved that issue by trading our ST in on a RT so I do not know if they would have fit, but I still believe that they would.
    I hope you find a solution!
    BTW Welcome!!
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    An expensive; yet effective solution!
    New seats, or handlebars $500 and up.
    I ended up putting 3" risers on my RS handlebars, but not sure that can be done with the ST.
    Active Member AppleSpyder's Avatar
    Tombstone, AZ
    I have the same problem with aching shoulders after a while when riding. I am going to be purchasing a Corbin Lamonster seat, after I save up a little more. I think that will bring me down into the right position and get rid of the tilted forward position. That's my thought anyway. If that fails I'm going to look at some handlebar risers.
    2016 F3-L Special Series Triple Black
    August 25, 2016
    2014 ST-Limited
    July 2, 2014
    "Just going down that long lonesome highway" and now REALLY loving every minute!!
    Active Member Ccol's Avatar
    Jan 2013
    Sunshine Coast QLD Australia
    This has been tried and tested ..... the owner is very happy with the result......
    http://www.lindsayroland.com/pdf/Add...toSpyderST.pdf
    Bossier LoUiSiAna
    Just a guess , but you sound like looking for excuse to get adjustable F3
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
