Results 1 to 15 of 15
Thread: Radio Antenna
    Dec 2014
    Quitman, Texas
    Default Radio Antenna
    I am new to this site and this is my first post. Also, I am a new Can Am owner. I have a 2014 Limited and the radio antenna was broken off. Do any of the repair manuals illustrate how to replace the antenna? Any help is greatly appreciated. Thank You
    Bryant, Arkansas
    Quote Originally Posted by Cagey View Post
    The antenna mast just screws into the holder beneath the tupperware, just pull the rubber boot off, unscrew the broken or bad antenna and replace it, be sure to replace the rubber boot to prevent water from entering.
    If you need more info please tell us what info you are looking for and we will try to help.
    Cruzr Joe
    Jun 2012
    Concord, NC
    Cruzr Joe
    In my case, they either cross threaded, or used threadlocker. Next time I'm back there, I may need to take the block out, and put it in a vice. Luckily, my antenna isn't broken, I was just thinking of replacing it with a shorty.
    Active Member Empty Pockets's Avatar
    Apr 2013
    Monument, Colorado
    That happened to my Spyder as well dealer took care of it as a warranty issue
    Bryan
    Default ANTENNA REMOVAL
    You can slide a 7 mm socket down what's left of the shaft if any and then grasp it with vise grips.......But before you do this use some BRAKFREE or similar stuff first....good luck.......................Mike
    Since they've got the "Antenna Part" of the conversation covered...
    Active Member NU2Spyder's Avatar
    Nov 2014
    Hammond LA
    Default Nu2Spyder
    Drill out the antenna from the base and glue the antenna back in the hole you drilled. My question is, where can you get a boot that fits other than dealer?
    x 2.
    Quote Originally Posted by NU2Spyder View Post
    You can't ... That boot is tapered especially to match the slanted contour of the hole that it fills.
    Oh!
    Bossier LoUiSiAna
    image.jpgMine didn't break just made custom. Forget what thread it was, may sell original, fyi is a '13 , pm me
    Sep 2014
    East Texas
    Default Face it and go to the dealer.
    Warranty or out of pocket, you might as well fix it right. Don't even consider doing anything besides putting the correct antenna and rubber boot back on it. Reception is only OK under normal conditions so don't cut corners here. IMHO
    Mod Monster Phil's Avatar
    Nov 2010
    Tyler, Texas
    Cagey- I'm in Tyler if you want me to look at it. I agree that your dealer should handle it as warranty, but I'm happy to check it for you. Feel free to email me - genesis@genesisworld.com and I'll get my cell number to you. We'll conquor this!
    ____________________________
    Phil - Tyler Texas
    2010 RT-Premiere Edition (Named DARTH) | Timeless Black | All My Mods--- ARE HERE | Phil. 4:4
    Mar 2012
    Indianapolis
    go to Wal-Mart and look for antenna that costs about $9.00. I put one my 2012. search on this site for it. I found it here. It is a warranty problem hope you get it replaced by dealer.
    Active Member RockyMountainRider50's Avatar
    Mar 2014
    CO
    Default Check youtube!
    Check out my youtube video titled Can Am Spyder RT antenna repair. Hopes it helps you.
    2012 RT LTD & RT-622 , Pearl White
    Mar 2013
    Michigan
    My antenna broke off last year. I have the antenna. I don't plan on using the radio. Can I just remove the part that is still on the Spyder, smooth the rough end on the broken part then re-insert the slightly shorter mast?
    I have a 2012 RT SE5 with the audio package
    Rob Harris, USN, ret
    Thank you all of our future, present and former military for your service throughout the world.
