Tool Kit
Here is a question for you more experienced riders. Besides the toolkit that comes with the Spyder, what tools do you recommend carrying with you 1. At all times, and 2. On long trips.
If it makes a difference, I have a 2014 RT se6.
Thank you,
Ken
I don't remember the sizes, but I carry a bunch of the Torx bits and a driver that you need in order to pull parts off of the bike...
Originally Posted by Rattigan_Roger
The Cosmic Rule of Tools applies, You can’t carry everything you will need but a hammer and a bottle jack will help to keep peace of mind.
That bottle of Jack is to drink when all else fails to get going again
2014 RT S SE6 Cognac. Built on 12/20/13.
2014 VW EOS 2.0 TSI replaced the RT S 5/22/2017
A T-20 and T-30 and a 5mm allen key will cover 90+ % of the non-hex head fasteners. Most of the hex heads are 10 and 12mm.
Tools what are those I always make sure I have lunch and beer packed Anytime I work on the Spyder at home I check the tool I am using and see if its in my tool bag I have on the Spyder.If not I buy another to add to the Spyder tool bag.After a few times doing basic Spyder stuff you will have a nice set of tools for the Spyder tool bag
2014 RT-S SE6 Pearl White
Grip Puppies, 12 volt power outlet, BRP comfort seat, Tri-Axis adjustable handlebars, BajaRons sway bar & links, Spyderpops Bump Skid w/Inlaid LED's & Stainless steel Kott grilles,SmoothSpyder belt tensioner,Carbon fiber dipped wind deflectors,Lamonster NBV highway brackets,Lamonster cat delete pipe,
I carry a small Harbor Freight tool bag.
I moved the under seat tool kit to this bag
Added a small compressor, tire plugs and plug tools
An assortment of torx bits, I think a 10mm wrench, and wrenches to remove my flags for when I'm on a trip and need to cover the Spyder.
Other than that, my BEST warranty card is in the glovebox, and I keep the cell charged.
I've never had to use anything (except for the wrenches to remove the flagpoles)
Invalid Emails
My input
TOILET PAPER and an attitude that finds adventure in all!!
...and then I have most things that Rattigan_Roger recommends as well as others. I do NOT know what to do with such things (called tools), but I am prepared for the helping hand that will come my way or for loaning to another in need. Now as far as "towing"...BRP roadside assistance is Poor at best...so add either AAA (Premium RV) or Good Sam (Platinum)..verify it is covering your Spyder..some of their plans do not. Also, read the manual on how to tow...I have had to use roll back 3 diff times ( no worries that was over 100k of Spyder travel and one was my issue...knew I was probably needing a new battery...aaaaa waited to long!!!)...I hand them the manual open to correct page and say please do as this says....sent one driver 'packin' cause he said he knew everything and did not have to look at the manual...after I asked him to give me his "how to"...I said thank you, BUT NO thanks.
Oh yea and a good book to read if you have to wait for the tow truck...and nothing entertaining to look at!!!
My Motto Is:
Live my life in such a way that when my feet hit the floor in the morning...Satan shudders & says "Oh, crap, SHE'S awake!"
Red Stallion: 2016 F3t SE6 (from Pitbull PowerSports/ Springfield, MO)
White Knight: 2014 RTS SE6 and matching 622 trailer (from Pitbull
Ms Spydee: 2010 RT SE5
MOgang Member
What everybody has said and zip-ties, safety wire, diagonal cutters, duct tape and electrical tape.
Also, a small medical kit and R. Roger's phone app can come in handy .
I keep them on my Spyder at all times. Never know when something's going to happen...
Reason: spelling...
Joy
Very Happy Ryder... '09 Phantom and a '15 F3-S
If you don't slow down, they can't catch you..
If you don't give up, they can't win.
What a long strange journey its been.
What's in the tool kit.
You are getting a lot of recommendations for what is already in your tool kit.
Already have the screwdrivers to remove the outer panels. 20T, 30T, slot and phillips.
Several sizes of hex drivers and a couple wrenches. (the 13mm open end needed to manually shift a SE5 in an emergency.)
A 5 & 6mm allen wrenches.
The tools are maybe of questionable quality but good enough for the extremely basic roadside repairs. You need to ask yourself what kind of roadside repairs you are willing to tackle.
IMHO most breakdowns on the road are rare and would in very many cases need repair parts.
I carry a flashlight.
A roll of electrical tape.
A needle nose and lineman pliers.
Sidecutters.
A roll of double sided velcro.
MicroStart jump starter pack.
2018 F3 LIMITED
Check your tool kit that came from BRP. Mine had a double ended Torx looking thing that fit in the handle provided. Problem was, the quality was so poor it did not fit the fasteners on the bike.
I also found on mine that one of the torx was a size I haven't found on the bike yet. Thus I added my own torx bits to the toolkit.
Tools....
many problems seen here are not repairable on the road side so the cell phone and Roger's spyder code app will be your best tools. For those that do dabble in the mechanical/electrical...a tire repair kit and small compressor/pump. Electrical tape, duct tape and zips and the antigravity charger/jump starter. A few additional tools as well. Many stores carry kits...
2012 RS sm5
I am a pack rat and probably the last person that you want to hear from.
But here goes.
Since the Spyder is primarily an electric device, a good VOM (Volt Ohm Meter) is essential.
You can’t begin to diagnose a road problem if you don’t know things like VBat or if there is continuity
between the SE5 (or SE6) solenoids and the cluster.
A good deep well metric socket set is also nice to have.
I keep a Bosch electric impact wrench on hand too along with the appropriate star sockets.
It makes emergency tupperware removal easy.
A spark plug socket and a 36mm socket (for rear wheel) is nice to have.
A 6” 3/8 extension and a wobbler is also nice.
A good Jumper Box is also helpful.
This is why it's a blessing to travel with Roger. He's like a Guardian Angel!!
toilet paper. good idea, but instead carry bounty paper towels..(multi-function) .. i used slime and air canisters once.. what a mess.. it's too hard to get the slime into the tire.. pull the schreader valve etc.. a large can of pressurized flat proof is much better, in my view.. i have had several flat tires after the slime experience, and the flat proof saved the day... be sure to warn the guy changing your tire, about what's inside! .... i always carry 3 ft. or so of pliable bailing wire.. if one would loose plastic fasteners, and then suffer a loose panel or whatever may come loose, along with pliers, the wire could help.. these are things that a non-mechanic can use, to find his way home... remember that saying, all the criminals use, when running from the cops....... "i just want to get home" .... i must say, i do not own a spyder (yet).. but i have had many street bikes.. i ride mainly by myself up in the mountains above ventura ca.. spotty cell reception, along with hardly any other vehicles on the road, teach one to be self-sufficient..... life is good ..... chuckk ...
Craig (& Tee ) in Bakersfield
He's just this I.T. and Voice Over guy.
Our rides.
2012 Can-Am Spyder RT-S SE5 4400 miles
2008 BMW 328i E92 (Coupe) 127500 miles
2005 Chevy Tahoe Z71 4x4 224600 miles
But here goes.
Thank you everyone. Especially Roger. I would want your opinion all the time. I downloaded your app months before I had the Spyder. I do appreciate everyone's input.
With all these suggestions I will not have enough room in my RT 622 trailer for my cloths
Now 2014 RT Limited Cognac
Was 2008 GS SM5
Don Garbarino
Cup Holder
GPS locking holder
Mud flap
Modified KNOTT grill
Phone holder and charger
Trailer hitch
Dual air horn
Auxiliary fuse box with relays
Heated clothing controller
volt/oil pressure gauge
Sequential signals in mirror
Tri Axis Handle bars
Baja Ron anti sway bar/heim links
shorty antenna
And many more
This may be a stupid question but i was out with my brother on his 2012 RT last week and the right side panel was a little loose so we went to tighten it up with a torx or star bolt whatever you want to call it but his have little nubs in the middle of the head so a regular torx driver wont fit, i figured his tool kit would have one but it just had a regular torx, how do we tighten those up or get them off. My 08 GS doesnt have any of those locking bolts or whatever they are called?
thanks
