Spyder Oil Stick Reads ADD
Okay Lets see if I can get this right. I have 2010 Spyder RSS, About 2,300 Miles on it. I just checked the oil today and it is at the ADD level. Can i go to walmart and buy oil and then just add it in the oil container? and how much should I add? 1 Qt 2 Qt ? and what oil do you guys recommend? I am going to take it for a 3000 mile service but Just until then I want to make sure there is oil in there. I dont know why the oil would be so low? could it be that I ride fast and it eats up the oil?
Here's the thing..!!
these engines use oil. You should check the oil every 300/500 miles and it can be 1/2 qt low give or take depending. I like to check it right as I end a long ryde with the engine hot. Your manual tells you the right way to check the oil. You can not check it cold. You are better off getting some qts of the same oil that was used at your last oil change. There are oils at auto parts and walmart but you have to make sure they are the same specs..check your manual...
2012 RS sm5
SpyderLovers Sponsor
DO NOT add oil yet
I would go to the BRP dealer and get the BRP approved oil they use, if you
only have 2300 miles on it it may not even have had the orig. oil changed yet..
Don't mix the oil with cheeeeeeeeeep oil.
Dave
Make sure that you are checking the oil when the engine is completely warmed up. Follow the directions in your Owner's Manual
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Walmart stocks Valvoline, Mobil1, and Castrol Motorcycle oils.
As long as the bottle says 10-40 and Jaso Ma or Jaso Ma2 you can use it and mix it with BRP oil with no issues.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Go to your dealer, and pick up some of the proper oil for the bike...
Some of the others will work just fine; what is your peace of mind worth to you?
It tells you on the side of your oil tank, the recommended oil to use, and if you can't get the recommended
oil, call your dealer to get advice on an alternative.
And as others have said, read your manual and check the oil as per the instructions.
We now have His and Hers Spyders.
Current Spyder, 2015 F3 Steel Black, Passenger Backrest, Blue Ridge Screen with Xcreen Extention, Akrapovic Muffler, Attitude Handlebars, Blades front rims, RT Swaybar,
Her Spyder 2011 Magnesium RSS Sportrack and Backrest, Comfort Seat, Grip Puppies, 3.5 inch Riser Bars, Wespyd Signature Swaybar. Hindle Muffler, Godiva Screen, Hiway Pegs Can Am Panniers
Previous Spyders
2013 ST SM5
2011 RSS
2010 RS
