Results 1 to 13 of 13
    Nov 2014
    turkey
    Default Help i am new forum
    Hi everybody i have a 2014 spyder rss i am from turkey
    i have two bros exhaust k&n air filter and have a cat bypass from spyder1attitude
    i want to learn i must use power commender or juice box
    and my second question is how can i find map ?
    thank everbody
    The "experts" will come on with some help shortly.
    Nov 2014
    turkey
    Thank you
    I'm sorry that I can't help answer your questions, but I wanted to say also!
    Nov 2014
    turkey
    Thank you your welcome
    Sep 2012
    Junction City, KS, USA
    I also can't help with your questions, but I'm sure someone here can. You've come to the right place!
    PrairieSpyder (Patti)
    Nov 2014
    turkey
    Quote Originally Posted by PrairieSpyder View Post
    thank you your welcome.
    Just a bump for our new member.
    Any knowledgeable SL that can answer the OP question?
    When it comes to exhaust and juicebox stuff, I'm Out, as they would say on Shark Tank.
    Default Welcome..!!
    why do you think you need to have a fuel controler..?? Depends on where you are, but check your running and plugs to see how your spyder is handling the change. I have pipe and removed the air box for a JT air filter system with K&N and do not have a controler....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    washington state
    and
    2012 Spyder RT SE5 Brake pedal mod
    Nov 2014
    turkey
    thank you because my last can am spyder rss was 2011 and i was have two bros dual carbon and juice box without juice box spyder on slow speed bad but when i put juice box it was getting high speed quick
    Registered Users Spyder ri's Avatar
    Warwick, RI
    I have a 2012 RS with a two brothers single exhaust and K&N exhaust. I am running a Juice Box Pro with a power commander map for this setup. Just go to powercommander.com and download the map. The map will load into your juicebox when you plug it into your computer. If u need more info, just PM me.
    Registered Users Zoup2nuts's Avatar
    Sep 2014
    Cascade Colorado
    Default ...Juice box..
    Quote Originally Posted by Spyder ri View Post
    Hello, I have a 2010 RS and I added the two-brothers dual carbon fiber set-up with the Juice Box. The Juice box can be re-mapped, but the map that comes with the juice box is programmed for the two-brothers exhaust and works perfectly. I'm in an area that goes from 6000' elevation to 11,000' elevation on many rides and it has never sputtered on me. I have been told that sometimes, the juice-box is not necessary, but the previous owner put in a custom air-box and air-management system with the K&N air filter. So, I guess I'd run it for a bit and see if there's any popping on deceleration. Good luck, you're going to love the Spyder..Bob.
