2011 RSS Check Transmission
Went for a ride and got 4 Check Tramission lights. Wouldn't shift from third. Shifting solenoid?? Oil level is fine, only 200 miles on oil change. Help please
I know you said only 200miles on the oil change but I would check that first.
If you ryde like there's no tomorrow, there won't be any
Accidents hurt - safety doesn't
Let's see..!!
you checked oil and it was changed recently. Filters (both) as well I hope. You should check the linkage (shift arm) which have come loose on occasions limiting shifting. Others would be the paddle shifter and the selonoid....
2012 RS sm5
Check your shift lever. It may be loose. You can find it under the tupperware in front of your left foot peg. If it can slide on the spline shaft it needs to push all the way back on and tightened.
2018 F3 LIMITED
