As promised here is the report on the Mobil 1 4T 10-40w full synthetic oil after 6234 miles. The motor has 15234 miles on it at this point. The BRP semi-synthetic 5-40w did well in the test, but sheared to a 20w at 6000 miles.
The first column is the Mobil 1 and the thrid column is the BRP semi-syn. The cSt Viscosity @ 100c is the weight rating of the oil. The Mobil 1 is just above 30w and the BRP is at 20w.
I noticed no difference in drivability between the two oils, or any differenc in the sound of the motor.
Currently I am running BRP full synthetic 0-40w oil and will have that tested at 6000 miles also (next year as winter is fast approaching). The reason I am doing this is to know what oil works the best and not what I think/feel is the best.
2021 Sea To Sky, 2020 RTL
Isn't it weird that in AMERICA our flag and our culture offend so many people...... but our benefits don't?
Great info! The M1 held its viscosity really well. The high moly and boron should be taken into consideration. They are friction modifiers, which might make me twitchy in regards to some wet clutches...even though it says its spec's for it. Good for engine wear though.
Also, if you use a high moly oil keep an eye on your copper wear. Moly can cause detioration of copper as it traps moisture.
This seems like it could be a really good oil for the 1330 machines!
PW: Thanks for the report. First one I've seen on M1 oil and in my book, an exceptional showing with that many miles (6K+) on it.
It does appear to be in the mid-30W range based on this chart (http://www.bobistheoilguy.com/viscosity-charts/ but several well known brands of synthetic oil I've tested had dropped to 30W down to 20W by time they hit 4000 miles. Some even at 2000 miles.
I would think M1 might be a good 5000 miles oil, changing the filter every other oil change. If one were running in a very hot climate, throw in a quart of 20-50 to really hold the viscosity up.
If anyone sees it on sale, give a shout. I believe one of the auto stores, either AZ or AA, has a sale once or twice a year, but not sure when. Its about $10+ at Walmart anytime.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
.......@ Wally World 4T 10W-40 ,$ 9.97 Qt........also 4T 20W 50 V-twin Racing for $ 9.97 Qt.............Yea the Rotella T-5, 5W-40. is Half this price, but I don't know yet what it will test out to be ? ? ?....................just sayin, Mike
Note: The 20w50 has not been rated JASO or MA(yet)
Great info provided here. The idea of testing to see what the best oil is for these bikes is great. Some brands have a great following but only testing in the real world will tell the truth.
I noticed you posted at 6:34 AM... It's only oil CYA on the road
Grandpa Pete
Caswell Ryder and general PITA
Sorry for the late post time, but it does take me a little time to wake up . I start work at 6:00am and get up at 4:00am so don't tell my boss that I did this at work
See you on the next ride
..............This is good to know Thanks..............I wonder if " ulflyer " is aware of this ,...He has advised to throw in QT. a to help LESSEN the effects of " SHEAR " ...Mike
Good results on the M1. I would switch immediately to it, but I am still a little leary about the wet clutch issue. Think I'll wait a bit. As long as I change mine with BRP blended at 6K and do the filter every other time should be OK. I don't run the bike that hard and that 20 wt should be fine. Might throw a qt of 20w50 in in the summer. Does BRP even make a 20w50 in a blend?
I had no clutch issues in the 6000+ miles that I ran this oil. I am not aware of 20-50w oil from BRP
Would you be willing to ask Blackstone if they have a baseline on the M1 moto 10-40. Primarily focusing on how much Moly is in the oil when new.
Overall though, I am not disappointed with the numbers and still plan to run this at the next oil change.
PK
I sent them an email asking and will post their answer. I know a few years ago that Motorcycle Consumer News did an article comparing motorcycle oils and I will see if I can find it.
..............This is good to know Thanks..............I wonder if " ulflyer " is aware of this ,...He has advised to throw in a to help LESSEN the effects of " SHEAR " ...Mike
I'm pretty sure the Mobil 1 20-50 is rated the same as their 10-40. Seems I've seen JASO Ma on the bottle. Will be at Walmart today and will give a look. Amsoil and Valvoline 20-50 is rated Ma2 as well as many other brands.
Edited to Add: The bottles of M1 20-50 ARE NOT marked Jaso ma, much to my surprise, but as stated above the 10-40 is.
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
The test number was about 52 for the Mob1 and thats in the range of what I've seen on several Amsoil tests I've done. I asked the guru's on BITOG a good while back "what would be considered too much for wet clutch bikes" and forget the exact answer but it was somewhere in the 3 digit range. Will see if I can do a search and get the exact answer.
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
A study of motorcycle oils - 2nd edition - conducted by Amsoil
Updated with new test results and expanded to include 32 different motorcycle oils, A Study of Motorcycle Oils – Second Edition (G2156) describes and represents the properties of various motorcycle oils which were purchased and tested in 2008 through early 2009.
