Have canam trailer hitch..what hitch Hauler or Carrier will fit this for cooler,etc.?
I have the canam trailer hitch and now would like to get a carrier or hauler for the hitch. Where do I look for it ?
thanks
Try Rivco. Just remember to not put anything fragile into a hitch carrier.
http://www.rivcoproducts.com/products/home.php?cat=397
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
I purchased an aftermarket hitch and mfg a platform.20140913_081635.jpg20140913_081655.jpg
The problem I had was the platform sticking out too far caused the hitch to sag.
so I removed the hitch and welded some stiffeners to the underside.20141023_112346.jpg
For the platform I purchased one at harbor freight that was way too big and I took it apart and made it much smaller.
The total weight for the platform and the "Really Usefull Box" is about 6 pounds total.
I only had our 2 helmets and our rain suit in it and it still bent.
Stefan
Box?
Stefan
What is the box you used and where can I find it?
Thanks,
Charles
I had looked at http://www.pakitrak.com then decided with a trailer from www.minitrailerusa.com. That way had room for cooler and some cups
RIVCO Hitch Racks not recommended for unsprung hitches
Originally Posted by SpyderAnn01
Thanks for the mention SpyderAnn01! We do make very strong hitch racks and attachments here in Wisconsin (strong enough to support a person's weight, and rated at 35lbs on the road), but we can't recommend using them with un-sprung hitches like on the Spyders because of the vibration and shaking. If people follow that link above, they will see that on the rack descriptions we don't endorse use on un-sprung hitches. All our best! The folks at RIVCO
RT-S PE#0031
I agree. The BRP hitch rides on the swingarms, so is impacted with every bump the rear wheel rolls over. I would guess that would accelerate metal fatigue immensely.
Mark & Mary Lou Lawson
Snellville, GA USA
'10 RT-S PE #0031
'10 RT-622 Trailer
'08 Yellow SM5 #2332
'01 Black GL1800A Goldwing #0930
"Remember in the darkness what you have learned in the light." - Joe Bayly
