tank bag install
what are everyone doing about the rubber piece around the steering post
when putting on bag .wont fit under bracket. thinking just cut it even across ? thought's
HAPPY TRAILS SPYDEE PE#53
If you are talking about the BRP tankbag, I had no need to do anything with the rubber around the steering post. The bracket bolted right on with no interference from anything. Not sure what to tell you. Perhaps someone else can chime in on this one.
Happy owner of Silver PE #1232
All The Gear All The Time - ATGATT
Gulf Coast SpyderRyders
Checked my valves myself. Were all in specs.at 10k
It would be great to see a picture of the bag mounted on Spyder.
2020 RT Ride Frequent Stay Safe
Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
Backrest Home Brew Mod
2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
Very Helpful Member
When we mounted dltang's BRP tank bag, the rubber was kind of in the way but we just pushed the bracket into position over the rubber and bolted it on.
Tank bag mount was easy. It was the bag itself that was hard. However I found that unzipping the bag itself before trying to fit it the first time made a big difference.
Senile Member
Same problem here. I thought about cutting it too until I read this thread. Now I will try to stretch and force fit the bracket.
Not an easy job!
I found it very difficult to fit as well. Had to use considerable force to push the bracket down enough over the rubber to line up the holes. It eventually worked, but only after much sweat and cussing.
Bruce
Bruce Brown
London, Ontario, Canada
Spyder Ambassador (Ret.)
2009 Moto Guzzi Stelvio "Silvia Dionisio"
Help us fight prostate cancer: http://motorcycleridefordad.org/
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, 'WOW, what a ride!'"
Senile Member
A much easier way
I found a much easier way to put the tank bag bracket on. It's a two person job !!!
First, install one bolt on one end. Hand tighten the bolt and leave some wiggle room. Then find a short length 2x4 as your push bar. While standing on the seat, using the corner of the 2x4, push down with your weight. The 2nd person line up the bolt (holding up the nut/front assembly bracket with your finger helps lining up the bolt) and thread it in. Tada ... done in 30 seconds.
Just becareful not to put so much force on the 2x4 so it slips and crushes the other person's finger.
Instructions for mounting the Tank Bag
Can anyone send me a pic of where the tank bag mounting bar goes? I just moved and lost the instructions. I know it is likely simple but for some reason my pea size brain is struggling! Thanks to all on this forum. Your knowledge and love for the Spyder keeps me informed and tracking!
Mole
Mole
Hows This. Just noticed this doesn't show the rubber. This is from the electonic workshop manual
Reason: Missed a bit
Trumpybob
A Very Happy Spyder Owner
Mole
welcome
I was able to install the bracket and leave the rubber piece in its place. Wasn't easy but doable.
Thanks Bob! Got the bracket on by forcing it over the rubber, but now the center panel is bowing up some in the center. Well I went and refit the center panel and got it to fit properly once all the tabs were set right.
So bag is on but me being the bone head that I am lost one of the two plastic pop-rivets which secure the center panel under the seat. Anyone know a good replacement? I am going to check at autozone. I think I had previously seen something there.
Thanks!
Mole
Mod Maniac
Thanks!
Mole
Cycle Gear has them in packages of ten for about $5.00.
ata = allergic to asphalt
My mods: https://www.spyderlovers.com/forums/...ead.php?t=5753
There are two kinds of people: (1) those who can read, reason and apply the experiences of others; and (2) those who just have to pee on the electric fence. ataDude, 2009
My Spyder:
Thanks ataDude! Do you got a weblink to the push rivets? Very much want to get a few extra.
Mole
Mod Maniac
Mole
Nope... found them in a Cycle Gear store five-six months ago. A lot of sport-bikes use them.
My Spyder:
I've seen them at hardware stores...either ACE or ACO...I can't remember which one.
Number One: 2008 Yellow GS SM5. I love my Spyder.
Number Two: 2012 RT-S Limited (the poop colored RT) I still have Number One, but Some Girl made me buy Number Two...
Thanks guys. I found a pair at AutoZone that are the screw in type. So what I did was remove one that was holding the left side tank cover under the seat to the center bar and placed it on the center panel. Then put the screw in replacement to backfill the one I swapped.
Mole
Speed mounting
My entire installation took about 60 seconds.
After the strenuous action of turning the key to lift the seat, I inserted the tab under the body panel. Then, with the forward loops closed, I hooked a balled shock cord from one to the other around the steering stem.
Done. Works fine, and all vestiges go away much quicker.
Ride on.
Roadkill
