Results 1 to 16 of 16
    Jun 2014
    California
    Default Anyone Use This Lift For Spyders
    Sep 2013
    Houston
    Looks interesting but have my doubts. Looks like it would not have sufficient reach for a Spyder and would be unstable if it did barely reach. But I have no personal experience with it and would LOVE to be proved wrong.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Default Don't know..!!
    I agree in that the reach looks a bit short. You would have to remove the tupperware on the side you are using it for full contact. There is a better one but much more expensive. I use the atv/motorcycle lift which works well. Got mine through sears for a bit more but better quality. Maybe someone here has one and knows for sure...
    ​2012 RS sm5
    Default SIMILAR
    Quote Originally Posted by OwnerOfHarriet View Post
    ....................I bought a similar style lift ( in that it has the two arms ) from Sears about two years ago ...on Sale for $79 and I really like it.....Harbor freight has almost the same thing as Sears ......They both operate the same way a regular car / truck floor jack does .........Mike
    Active Member Dragonfly's Avatar
    Apr 2013
    Atkins, Arkansas
    Bough this from Sears several months ago on sale with free shipping all the other jacks did not offer sufficient clearance to lift the Spyder without driving it onto something first.
    http://www.sears.com/craftsman-profe...2&blockType=G2
    Has extensions so you can lift an additional two inches but still use stands for extended work. Fast and smooth jacking up but drops like a rock if not careful and has a mechanical lock.
    Oct 2014
    Deep South
    The capacity is listed as 1100 pounds. That is cutting it pretty close for an RT. I would try to buy one with at least 25% over capacity - especially from a supplier like Harbor Freight.
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi Art,
    Re: I would try to buy one with at least 25% over capacity
    Try this one,
    http://www.sears.com/atd-7461-1500-l...-SPM6450220309
    Jerry Baumchen
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
    Registered Users Topshotta's Avatar
    Apr 2013
    United States
    Quote Originally Posted by Dragonfly View Post
    Also have one of these, rolls easily under the spyder from either side.
    If you ryde like there's no tomorrow, there won't be any
    Accidents hurt - safety doesn't
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    MUCH PREFERED LIFT......
    http://www.harborfreight.com/1500-lb...ift-60536.html
    I PAID $49.99 ON SALE WITH THE COUPON....
    DAN P
    EASLEY, SC
    SPYD3R
    Apr 2013
    Atkins, Arkansas
    But at 5.5" will not slide under the Spyder at floor level or I would have bought that one and saved $100.00
    Default THIS LOOKS LIKE THE ONE I BOUGHT ON SALE FOR $79 ?
    Quote Originally Posted by JerryB View Post
    Hi Art,
    Try this one,
    Jerry Baumchen
    .....As stated above They will drop rapidly if you press down on the release pad.......However I learned a little trick that will only drop it about 3/16 th inch at a time ........Tap the release pad with side of your fist.................I also lowered the Black Cushion pads on the frame which makes it slide under the Spyder easily..................just sayin,.....Mike
    Aug 2012
    Western KY
    Default I don't know my 1st thoughts were
    Is the a medieval torture device
    Idaho
    These are the ones Lamonster has in his garage.
    Hi Art,
    Try this one,
    I have that one and it works good, but it isn't as good as the one above. Lamonster has some of these in an old stuff pile by the back fence!
    It will if the back air shock is pumped up to at least around 50 lbs +. At least mine slides under my RT. It does hit the water deflector though. It does have a very good drop rate control valve.
    Quote Originally Posted by SPYD3R View Post
    That's the same lift as the Craftsman. Just different label, so buy for the best price.
    2014 Copper RTS
    Jun 2011
    Near Lexington, NC
    Default Is there room to change oil?
    Do the type lifts shown above allow sufficient room for changing the oil, especially the 1330's with two drain plugs?
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Mar 2012
    NJ
    We have no issues with the harbor freight atv jacks fitting under our RS' s. Also, The trick to getting the harbor freight ones to lower slowly is to push the peddle all the way down and hold it down. The spyder will lower slowly. If you release the peddle or try to feather the peddle it comes down like a stone or jerky. It's a little backwards in thought but works.
    Mar 2013
    Hi Art,
    Try this one,
    Jerry Baumchen
    This is the one I have. It is a tight fit to slide it under the Spyder, but I found that if I lift up on the floorboard as I slide it under it then slides easily in. It doesn't take much effort to get that clearance - just an easy pull up.
    I have had this lift years before owning a Spyder so if I was purchasing a lift for the first time I would be looking at the other one Sears sells.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
