Results 1 to 8 of 8
Thread: Need PARK help
    SpyderLovers Sponsor 0992's Avatar
    Mar 2014
    Myerstown, Pa
    Default Need PARK help
    When you put your SE6 in park, does that lock all 3 wheels or just the rear or just the front 2?
    If I jack up the rear wheel, will the bike roll away or is park also locking the front wheels?
    0992
    Yup!
    And it's a VERY good question!
    Mar 2014
    Myerstown, Pa
    Quote Originally Posted by Doc - Riverside View Post
    It only applies the rear brake only. Front wheels are always free. I always use short 2x4s to block the wheels from rolling when I'm working on mine in the shop.
    Thank you, Now I know what to do.
    Very Active Member stormtrooper's Avatar
    May 2010
    Montville & Toms River NJ
    Cool I learned something today
    2014 RT-S SE6 Pearl White
    Grip Puppies, 12 volt power outlet, BRP comfort seat, Tri-Axis adjustable handlebars, BajaRons sway bar & links, Spyderpops Bump Skid w/Inlaid LED's & Stainless steel Kott grilles,SmoothSpyder belt tensioner,Carbon fiber dipped wind deflectors,Lamonster NBV highway brackets,Lamonster cat delete pipe,
    Default Only one..!!
    wheel the rear. It is cable operated and only applies the rear brake. So chock the fronts if you are raising the rear wheel to be safe...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Default WHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAT
    Quote Originally Posted by 0992 View Post
    0992
    ...IMHO.....there is no such thing as "PARK " with the SE-6 transmission......Do you mean -when you apply the BRAKE ....If YES , the Brake is for the rear wheel only .....The transmission should go into neutral by itself ....but that may not happen until you re-start the bike ................Mike
    Very Active Member ottawa-rider's Avatar
    Sep 2012
    Casselman, Ontario, Canada
    When the engine is not running, the transmission is disengaged regardless if you put it in neutral or not. That is why we have the beeper to remind us to apply the parking brake.
    2018 RT LTD , Black
    Apr 2011
    GREENVILLE, SC
    Default REAR
    REAR
