12 volt air compressor recommendations
Yesterday I had the misfortune of running over a rock with the left front tire. It must have broken the tire bead seal. The tire went flat. Luckily I was near a pull-off view area(I was on the North Cascades highway). Found a gentleman with a generator and air compressor in the back of his pick-up truck. Aired the tire up and off I go, went about 10 miles and tire goes flat again. After using 3 cans of flat tire fix-it, I made it to nice gentleman's home who had an air compressor. He offered to let me park my Spyder in his garage if the tire did not hold air. It was 5pm and about 50 miles from the nearest tire dealer. I was able to ride it home. With the 3 cans of flat repair the tire was out of balance. This got me thinking a small 12 volt compressor would a great item to have with me. Does anyone have recommendations?
Cabelas has a nice little one that's only about $35, and is just about pocket-sized!
Check in their Automkotice/ATV catalog for it.
Just went to local auto parts store and picked up a small one for car tires for about $20.00
I carry this:
http://www.amazon.com/Stop-Go-Intern...tor+motorcycle
Mushroom plugs work much better than the old style rubber strips (just keep the plugs lubed), and the c02 inflator takes up no room.
Eric
YNC(SS) (Retired) - U. S. Navy Submarines
2014 RT-S Cognac
3 seadoo's,CBR250R, Suzi GT750 waterbuffalo's x4, Rebel 250, MB5, '84 Alfa Spider, '97 Jeep TJ, '93 Saab C900CVT, '99 SLK230, '65 Mustang, '59 Fairlane, '48 Ford 8n
+1. I have the same one. Fits real nice in the back compartment of the RT.
2007 M109R LE - To many MODS to list. Its cheaper that way!!!
I just picked one up for the spyder and other things around the house. One word of caution that I hadn't thought about, my pump requires a 15 amp circuit.
cycle grear
I got one from cycle gear small and compact also picked up co2 tire plug kit
Moe
me too
Moe
got the cycle gear compressor. it was on sale recently for around twenty five shipped. plugs into power outlet, or battery tender pigtail.
it was fun while it lasted.
Stop & Go mini air compressor Amazon $36.00 with free shipping. Great reviews
Check out www.cyclepump.com. High quality, compact design
Thank you all for the suggestions!
I have the Slime compressor too... slightly heavy but great pump.
Just ordered one of those right angle, clip on valve chuck's from Best Rest... great little invention that!!
+1 for the cycle gear mini compressor.
If you ryde like there's no tomorrow, there won't be any
Accidents hurt - safety doesn't
Compressor
I have a DynaPlug Mini Pro. It appears to be an excellent product. Although I'm new to Spyders, I have a lot of 2 wheel time. My experience is that if one buys a compressor and plug kit, and brings it along always, then one is unlikely to get a flat.
2016 Freewheeler
2014 Spyder RT-L Pearl White (SOLD)
Akrapovic Silencer, BajaRon Sway Bar/Links, BRP 23" Vented Windshield, BRP Adjustable Wind Deflector,
BRP Heated Seat/Backrest, BRP Sirius, BRP Bluetooth Dongle, BRP Tri Axis Handlebars w/GPS,
CD Brake Light Modulator, CD Short Antenna, Elka 1+r Shocks, ISCI Brake, JT Dash Mount, Lamonster Cat Bypass, SP Bumpskid, SP Kott Grills, SP Belt Guard
Received today my order from http://www.cyclepump.com. The pump is made in the US and comes with a 5 year warranty. Hopefully no more flat tires.
Keep in mind, if a tire pops the bead a small compressor may not work since you need a blast of air not a flow of air.
Once you've used a co2 inflator you will never bother with those little 12v compressors again.....
