Results 1 to 10 of 10
    May 2014
    Texas
    Default Made rest for foot
    IMG_0305.jpgMade out of Aluminium ... held on with one stainless bolt.... bent at a angle that when you put your foot on it puts pressure on the floorboard and not the plastic wing. Nut is hidden inside the plastic wing.
    Central Oklahoma
    Default Very nice!
    simple and effective! Is that an SM6 or SE6? If its an SM6 (and depending on your price!) I would be interested in purchasing a set from you.
    2020 RT Limited , Petrol Metallic Dark
    May 2014
    Texas
    Quote Originally Posted by sduskin View Post
    Did this on my SE6... Don't sell them... but 2 1/4 inch bolts and about 8.00 worth of plate.... you can make them... drill one hole and bend the plate.... simple... Took a piece of cardboard.... made a pattern that I liked.... trim and cut the cardboard to the shape you like then trace it to the plate....
    If you decide to go into production... let me know!
    Very Active Member Vader's Avatar
    Jul 2014
    Hudson Valley
    Sweet! Necessity is the mother of invention! Where is it bolted on to,on the byke?
    May 2014
    Texas
    Quote Originally Posted by Vader View Post
    To the plastic wing look real close and you will see the bolt on top... nut is inside the wing cover....
    Jul 2014
    Hudson Valley
    Quote Originally Posted by bgame View Post
    I like the simplicity. Nice job!
    May 2014
    Texas
    Used nylon locking nut and it has never got lose in 2000 miles.... but it is one bolt on and one bolt off.... Like I said the pressure of your foot keeps the pressure of the plate on the foot board not on the plastic wing....
    Registered Users Top End Unlimited's Avatar
    Jul 2014
    Sarasota,Fl.
    Default Floor boards
    I'm in the process of making my own floor boards. They are coming along quite well and I will post pictures when they are completed. I have a 2012 RT and still have the hot foot. When I'm done with the boards, they will help to deflect the heat and also add a foot rest (highway peg ) for when I'm riding long. Wish me luck !
    Active Member Empty Pockets's Avatar
    Apr 2013
    Monument, Colorado
    Inspector gadget makes a version of those I have them on my 2012 RTS they work well
    Bryan
