Results 1 to 20 of 20
    Sep 2014
    S.E. PA
    Default 1st review of 2014 RT Limited
    OK, I loved it...Rode her for over 300 miles over the weekend...Now, coming off of 2 wheeled bikes after a lot of yrs, I expected some time to get used to the Spyder..Still not quite there yet but looking forward to more "getting used to time"...Anyway, 1st habit I have to break is not taking twisties so fast...Went on a road I know well along the Delaware River with lots of tight curves and felt like I shouldn't push the Spyder so hard..Two wheel cruisers are much better suited for that..Have to remember I am now on a full-fledged touring machine...Buut really, only issue I had with the bike was the Eco mode I tried out...So used to shifting by sound on my 8 prior bikes...And with the eco mode, for the 1st couple hrs, it had me shifting very early, like whenever the rpms hit 2400/2500...but then later in the ride, it wasn't telling me to shift into 2nd or 3rd until about 4000 rpms...may have to get that looked at....Overall, very pleasant ride and I think I have my last bike....
    Which road??
    We just came up 209; this past Saturday...
    But if you've got one in your pocket, that has some twisties in it; I'm all ears!
    Thanks for the review. It appears that most don't like or use the Eco-Mode, myself included. I shift by sound, for me that's 2750 - 3000 rpm's for most upshifts. I let the 2014 shift down by itself.
    Default Welcome..!! Welcome..!!
    To the roadste world and this site. Forget the eco which was probably put in to satisfy the epa people. It does not do much to help. Certainly not enough to make it worthwhile using it. Once you get the hang of things you will be able to take those twisties the way you like. There are some modifications to help like the BajaRon sway bar and better shocks. Enjoy your new ryde and later if you like make the mods...
    Clermont, Florida
    You are likely to discover just how fast you can take twisties with the Spyder once you become more accustomed to its handling. I always have to wait on Goldwings and Harleys when I ride curves - only crotch rockets leave me behind
    Jul 2013
    Picayune, MS
    Quote Originally Posted by BikerDoc View Post
    This.
    when I started with my first Spyder, I took curves painfully slow. Now I zip through them without little regard (but within reason of course... Being aware I'm not on a crotch-rocket).
    point is, you'll become more comfortable with it in time.
    congrats!
    Default OR THIS METHOD
    .....I normally have my 1330 in ECO mode ( for the gas mileage ) but I don't look at it........I shift by sound and feel ............always have ...always will .....Mike
    Sep 2014
    S.E. PA
    Which road??
    River rd on PA side of the Delaware river...I usually start in New Hope and ride up to Easton...Sometimes I start below Washington's Crossing....
    That's a lot further South than we normally get...
    I used to prowl both sides of the Delaware back in the mid-seventies...
    Right from Trenton; North to wherever we could find some trouble!
    Bryant, Arkansas
    Cruzr joe
    United States
    We did a Memorial ride with about 200 bikes and about 1/2 were Hells Angels. Those boys ride hard. Even new to the RT and riding two up we left them behind in the curves. Guy ask me what we had done to make the bike so fast. Told him it came factory that way.
    Lose the ECO. Less than useless and lugs the bike sometimes. Listen for that sweet spot for shifting (2700-3200). You'll find it. Also, play with the rear air suspension to find you best spot. And replace the sway bar first up. Baja Rons is ten times better. Enjoy your awesome ride!
    Boerne, TX
    Quote Originally Posted by Doc Humphreys View Post
    Would you guys explain ECO. Is this a fifth or sixth gear on the 2014? If you don't use it, what gear do you cruse in? Some say it is not useful....just wondering. Thanks
    Invalid Emails
    Apr 2014
    Northwood NH
    Quote Originally Posted by BIG RED 1 View Post
    It has nothing to do with gearing. With the advent of electronic throttles came the ability to program them. So eco mode is a combination of throttle response, timing changes, and other tweeks to how the engine operates that should result in better gas milage at the sacrifice of performance. It also incorporates a "when to shift" indicator which further smooths out the engine. I personally don't use it, but some guys turn it on and ignore the when to shift light.
    Central Oklahoma
    Default now have Eco turned off...
    Quote Originally Posted by sddinnh View Post
    I did some playing with Eco mode while driving home yesterday. With Eco on, the accel from the stoplights was gradual and required more throttle to "keep up" with the folks that stomp the accel when leaving the light. At 45mph, when turning Eco mode off, the rpm's came up and the spyder became more "lively" with no change in my throttle. Speeding up and slowing down became much crisper, more responsive. Next set of lights were done with Eco mode off. Much faster accel, less throttle effort to keep up with the cages. I will finish the tank of gas to see what the effects are on the mileage.
    note: I usually have the Eco tell me to shift either during or just after I have already shifted...
    2020 RT Limited , Petrol Metallic Dark
    Active Member Nito's Avatar
    Apr 2014
    Canterbury - UK
    Eco just changes the throttle map by softening the throttle curve and limiting max throttle to 60% of normal.
    1330 RT SE6 Timeless Black...
    "Tre Pistoni, Tre Ruote, Tre Mendo"
    SpyderLovers Sponsor
    Mar 2014
    Myerstown, Pa
    Which road??
    Route 125 from Pine Grove to Shamokin Pa is a good one. 50 miles and ice cream stops at both ends.
    I ride that one frequently and love it.
    Boerne, TX
    Does the '14 have six gears vs five on BR1? And I see you can turn off the ECO thingie....thanks guys.
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by steversssss View Post
    611 and 32
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jul 2010
    KILLEN, AL
    Same here.
    Jul 2010
    KILLEN, AL
    I don't need no stinking eco mode!
