Results 1 to 25 of 30
Thread: Low on oil
    New Orleans
    Default Low on oil
    Hello, my oil really is low can I just go to the auto store and buy some full synthetic and top it off? Is that ok??
    Default Depends..!
    if they carry motorcycle oil with the same specs. You would do better going to a bike shop. Manual gives the specs needed. If you are do for an oil change soon mixing oils would be fine otherwise try to keep the same oil. Whenerver you have an oil change get an extra qt for topping off...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Quote Originally Posted by spydersteve22 View Post
    Do not put regular automobile engine oil in it. You may get away with it if you don't put much in but, why chance it. Get a good 5w-40, 10w-40 or 15w-40 full synthetic with a JASO rating of at least MA (NOT MA1). MA2 is better.
    That part can be a bit confusing because...
    MA1 (Not too good and not good at all for the Spyder)
    MA (Better and good enough for the Spyder)
    MA2 (Best!)
    If you have to, 20w-50 with the same JASO rating will do. Especially for topping off.
    Active Member maliamd's Avatar
    Jun 2013
    Asheville NC
    How many miles on your bike?
    New Orleans
    1939mi, haven't did my first oil change yet and don't know what oil they put in first.
    Apr 2011
    GREENVILLE, SC
    Default NOVICES
    OBVIOUSLY YOU ARE A NOVICES.... NOTHING WRONG WITH THAT, WE ALL WERE AT ONE TIME... AND IT'S GOOD THAT YOU ASK THE RIGHT QUESTIONS.....
    GO TO YOUR DEALER, AND BUY A QUART SPECIFICALLY MADE FOR YOUR SPYD3R.....
    DO NOT TAKE CHANCES
    ALWAYS KEEP AN EXTRA QUART HANDY, FOR THE EXTRA $10, IT'S CHEEP INSURANCE... AND REMEMBER, ALL THESE ENGINES WILL BURN ABOUT A QUART BETWEEN OIL CHANGES... SO PLEASE DON'T THINK THERE IS SOMETHING WRONG WITH YOUR SPYD3R....
    DAN P
    EASLEY, SC
    SPYD3R
    Very Active Member cyclelover63's Avatar
    Mar 2011
    Big Sandy, TN
    Advanced Auto Parts stocks Mobil 1 synthetic oil for motorcycles that meet all of the specs..It is not in the automotive oil section though...You have to search for it...i bought it for top offs...I almost never visit a dealer without buying an extra quart of XPS,just for top offs...Can't always time it right though.
    Quote Originally Posted by SPYD3R View Post
    DO NOT TAKE CHANCES
    DAN P
    EASLEY, SC
    SPYD3R
    It certainly can't hurt, to have a quart (Litre?) of BRP's slippery stuff on the shelf... Get the blended stuff; it's what comes with the bikes from the factory.
    Houston
    You can also find Valvoline motorcycle oil at Wal Mart that meets all the specs. Its in the motorcycle section, not with the other motor oils.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Default ????????
    ​Valvoline has an OIL that is OK for the 998 engine ?????......Mike
    Mar 2014
    Alexandria, KY
    Default 2014 RT too?
    Quote Originally Posted by cyclelover63 View Post
    Does this hold true for the new 2014 as well?
    Reading thread, first I heard of engine "using oil" and needing to "top off". Coming from GL1800 that never needed oil between changes (now have RT-S 2014).
    The 1330s have NOT been showing a tendency to burn oil as much as the 998s have...
    Mar 2014
    Alexandria, KY
    Good to know Thanks.
    New Orleans
    Thanks for the info!
    New Orleans
    Oh! And what make going through Baja Ron cheaper then buying the Can-am kit for $50?
    May 2013
    SW MO
    Not according to their web site. Here are some full synthetic oils which will meet Spyder specs:
    Mobil 1 Racing 4T 10W-40
    Castrol Power RS Racing 5W-40, 10W-40 (JASO MA2)
    Amsoil 10W-40 Advanced Synthetic Motorcycle Oil
    (JASO MA2)
    Red Line Synthetic 10W-40 Motorcycle Oil
    Royal Purple Max-Cycle 10W-40 Motorcycle Oil
    Motul 300V Factory Line Off-Road 5W-40
    Motul 300V 4T Factory Line 5W-40
    Motul 300V 4T Factory Line 10W-40
    Motul 7100 4T 10W-40 (JASO MA2)
    Silver Shadow
    2013 RT-S Lamonster Edition (vented windshield,
    NBV highway pegs, Two Brothers exhaust)
    Additional Mods: SpyderPops BumpSkid, Elka 1+ shocks, BajaRon Anti-Sway Bar
    A Veteran is someone who, at one point in his or her life, wrote a blank check made payable to “The United States of America,” for an amount of “up to and including my life.”
    Mar 2013
    Quote Originally Posted by KyPadre View Post
    In the 13,000 miles I have ridden, and every time I have checked I have never had to put in any oil.
    Make sure you are checking the oil after it is at full temp like after a ride, but let it idle for about a min before you check to let all the extra oil settle (per BPR tech).
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Houston
    Absolutely. Valvoline 4T Stroke Full Synthetic Motorcycle Oil, 10W40. Good stuff and stocked at most WalMart stores.
    http://www.valvoline.com/products/co...oil/10w-40/129
    Houston
    Quote Originally Posted by OldCowboy View Post
    (JASO MA2)
    You did not look very hard: http://www.valvoline.com/products/co...oil/10w-40/129
    Its also been discussed here on SL a number of times and comes up in searches.
    Active Member BamaSpyder's Avatar
    May 2011
    Duncanville, Al
    Red face
    Go ahead; buy the kit from your dealer... Does the parts guy know what he just sold you?
    When you buy from Ron; you're getting someone in your corner; that KNOWS the proper oil for your application, and is more than happy to discuss anuy of the options with you.
    A REAL "Top-Shelf, First-Class" act!!
    How much did you spend for your bike?
    Do you REALLY want to try to save money, on something as important as oil?
    Default DON'T SAVE MONEY ON INFERIOR OIL
    .....Mike
    Default plus this one
    [QUOTE=OldCowboy;877020]Not according to their web site. Here are some full synthetic oils which will meet Spyder specs:
    (JASO MA2)
    Boerne, TX
    I buy a case of 10-40 synthetic Motorcycle Amsoil from Baharon....It is delivered to my front gate in 4-5 days....the only way to go. (much cheaper than the locals sell it for) Big Red 1 uses about 1/2 quart per 1,000 miles or so. I check it after each 500 just in case. Works for me.
    I traded my 2014 RT for a 2017 Mr. White RT-S. I am George Lewis. I live two miles from Boerne, TX. I am 89, retired USAF and Sony Corp. I also have a GW MotorTrike. My email: scoot62@aol.com
    SAVE THE CHUPACABRA
    If you have not been to Luckenbach, your journey is not complete.
    May 2013
    SW MO
    [QUOTE=BLUEKNIGHT911;877372]
    (JASO MA2)
    [/QUOTE.....This is also certified ....Rotella T-6 , Full Syn 5W-40 ....meets all BRP specs ...and is sold at Wally world for about $24 per Gal...Mike
    I am somewhat concerned about the Rotella T-6. The owners manual states that oil that meets the API SM spec should not be used. Rotella T-6 meets the API SM spec. http://s02.static-shell.com/content/...6-brochure.pdf
    Silver Shadow
