Spyder problem, no help in manual
Well, after all these years of trouble free RT spyders (12 Limited, 13 Basic and now 14 RT-S) i finally run into a problem that has not been discussed on this forum, let me explain
1 got dressed and walked out to my Spyder, turned the key on and waited for the computer to do it's thing, 12 seconds or so later it says "before operating read safety message then press mode button"
Now i intend to stay within my warranty guidelines and don't want to get in trouble so................. i reach up for the safety card and it is stuck, it will not come out.
ANY SUGGESTIONS?????????????????? PLEASE HELP.
so embarrassed by this situation that i won't even sign my name so you won't know who this is
Anonymous
I would report this to the NHTSA,Carlos an Rattigan Roger ASAP!!!!
Oh my goodness!! what a horrible thing to have happen to you!!! What are you going to do ?? If you don't read the safety instruction you can't ride!
Seems to me that BRP should replace your Spyder IMMEDIATELY!!
My thoughts exactly
That is serious trouble indeed Joe. Here's what I would do, go to the manual, on page 108 is the safety message. Find some good sharp scissors, cut it out a
nd then duck tape it to the glove box door, on the outside of course where you can read at any time Then take a picture and send it to BRP so they can add it to the file they have on you.
Dan
2014 RT-S SE6, 2012 RT-622 trailer
Warranty flat rate to "unstick" the safety card pays 1.5 hrs.
Sold my 14 RTS went back to 2 wheels.
2014 Kawasaki Vaquero SE
Ohhhh, you're good!
Originally Posted by NovaSpyder
That is serious trouble indeed Joe..
How'd you know it was Joe? The original poster was Anonymous.
Not reading the safety card will NOT void the warranty. However, the card retainer has a micro switch which when opened, counts the number of times the safety card is read before start. This goes in to the BUDS under safety card activation. After 250 starts without reading the card, the BUDS goes in to safety lockdown sequencing. There is no code for this available to the owner. The machine must then be towed to the dealer. The dealer must have a current BUDS program for unlocking the sequencer, resetting the counter and updating the ECM. Please note that once the system is reset the number of starts is reduced to 200 when the sequencer locks the system again. Currently there is only one dealer who has this program from BRP. They can't use it because their AST computer is down and their BRP tech only works on Tuesday and Thursday. Monday, Wednesday and Friday he shovels coal at the mine.
USAF '69-'89 E7
Thailand/Vietnam 1972
Well I was just guessing, Joe was easy to spell, but it could be Bob I suppose or Engelbert....
Dan
You are very bored that's what happens when you retire.
4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
NSA
maybe the NSA can help, they can find out anything.....
That's how BRP knows you haven't been reading it. After so much disuse, it sticks and you have to go to a dealer and confess, thus voiding your warranty!
the best way to remove that card is with a chainsaw. The sticking issue will be solved for good.
Corbin saddle
spyderpops block off plate, bump skid, belt guard
IPS
Tricled LED lights all around(too many to name here)
Smoothspyder belt tensioner
Custom Dynamics britesides
VTC floorboards, upper air vents, spoiler
BK car stuff HID upgrade
trailer hitch
Repainted rear fender, trunk latch assembly, switch cluster, gauge cluster
cell phone interface kit
travel cover that no longer fits due to the spoiler
New sway bar
New shock relocator
My salesman actually told me that you had to pull out the card to start the engine... I just nodded and smiled
Jonny
2013 Spyder RT Limited
- TricLED 3rd and 4th Brake Light
- Spyderpops Bumpskid with TricLED LED kit
- GloRyder Wheel Lights
- Spyderpops Missing Belt Guard
- Corbin Arm Rests
- TricLED Turn Signals
Yeah,
Cruzr Joe
Had that happened before....fixed it with a hammer and it never happened again!
Rewaco RF-1 GT
Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
0-60mph: 5.8 seconds
5 speed sync manual with reverse, mechanical dry clutch.
Front suspension: Trapezoidal fork with center spring
Rear suspension: Independent with Bilstein gas shock absorbers
Brake System: Grimeca calipers, linked ventilated discs, with booster
10.57 gallons
The cheap glue leaked. Leave it in the sun for an hour or so, and open it. Remove the sticker, and clean the panel with "Goof Off" or something similar. Find a "Do Not Mess with my Spyder" sticker, and place it on the now clean panel. Close the panel.
The panel now has a beneficial use as an additional deterrent for keeping admirers off your ryde...
2014 RT SE6 Rider
X - Honda Rider
X - RT S driver
X - RS driver
Lifetime VFW Member
You can always just leave it in the "deployed" position; it does a nice job of reducing the glare on the main screen!
I live in Califonia, and had this problem. It IS NOT covered by warranty. It took 1.5 hours of shop time to fix it! It cost me $135.00 at the dealer. THE MORAL OF THE STORY: PULL OUT THE CARD AND READ IT EVERY TIME. THE NANNY KNOWS IF YOU JUST PULL IT OUT AND PUSH IT IN. YOU MUST READ IT.
Dan
2012 Viper Red Rt
upgrades:
Baja Ron's Anti-Sway
Diamond-R Arm Rests
Gloriders
High mount brake light
chrome front fender garnish
Bad Boy Horn
Chrome Deflector Rack
Chrome Scuff Nose Accent
Handlebar Grip Fringe
Gremlin Bells
