VANDALISM! Broken antenna
Having a great time riding today and when we stopped to put the cover on the antenna just fell off in my hand. I am sure it was fine when we started out today. Even though those are fiberglass, they are still pretty stout, so someone must have vandalized it while we were in shopping. Since I know that the security system uses the antenna to read the key (I think), I was delighted that it started up and we were able to ride it home. No SEC codes have popped up and I'm wondering if there is a bare nub enough to let the key be recognized.
I really want to go to a steel one that has a spring mounted on the end to hopefully keep that from happening again. The thread on it looks like a 1/4-20, so it should be able to make something up. From what I can see, it is just a ground plain set-up, so anything with the same length probably should work. Any thoughts? Or has anybody been through this before. Kinda wondering what a OEM replacement antenna will cost. And kind of disappointed that Can-Am would use such a weak point for the security of the bike. If that knowledge gets out to the wrong people, we could all start having problems like this. A hidden ground plane antenna should have been used up close to the key. That would have been the way to do that. Not through the damn antenna. I hardly ever listen to the radio, usually Blue Tooth on my phone, so don't really need the antenna for anything other than the security system.
The real experts will get on here shortly, but for now. I do not believe the antenna has anything to do with the key/starting system. I had no antenna on my GS and none for a year on my RT.
There are several antenna threads on here. Them breaking off is dicussed/cussed several times.
Good luck
Oldmanzues
The "security system" uses a ring antenna near the ignition switch.
Thanks for the info. I read something about an antenna and the DSS, but it evidently is not the radio antenna.
Just go to Walmart and by the Schoche rubber duckey antenna. Direct replacement and will never break again. Less than $10. This is a common problem with OEM antennas.
The DESS antenna is in the shape of a doughnut around the barrel of the ignition switch. The key must be within less than an inch of the antenna to work.
a simple fix unscrew the antenna from the base on bike and drill out the fiberglass inside leaving the wire at the bottom for connection. then trim the antenna down 5 or so inches but make sure copper wire is exposed thats in the center of antenna. Epoxy it back in. then screw back on to bike mount. A savings of 50-60 buck for oem that will just break again within a month if your as lucky as I am....
OR THIS ONE
One of our brothers here ( PMK ) found another option in the Antenna area. It's a HIDDEN stick antenna that can be had with a 6 Ft. cable exiting from the end. This is long enough for you to place the antenna alongside the outside of the " FRUNK " which can be accessed by removing the PANEL just below the mirror on the right side ( use the right side because the 6 ft. cable needs to be on that side to reach the radio.) .......Mikeguyver
13 ST Limited F/R suspension, Corbin, GIVI top case
16 Vespa Primavera 150: Stock
16 Piaggio BV350: Suspension, braking mods in work
14 HD XL1200T: F/R suspension and brake mods; Corbin saddle and bags
09 Aprilia SC250: F/R suspension and minor brake mods
97 Honda PC800: F/R wheels, F/R suspension, and F/R brake Mods; Corbin saddle
90 CB-1: In work, long term project
89 Honda NT650: F/R suspension; Corbin saddle
GOS member (Girls On Spyders)
Doubt it was vandalism
Riding down in the Smokies this past week and checked my antenna only to have it fall off in my hand. Checked the connection and it had broken at the screw threads. This is the second OEM antenna and lasted for 3 years, lost the first after 2000 miles. Looks like bad equipment and many have told me to replace it with a shorty from Wal-Mart. Bike ran just fine without it so probably won't hurry to replace as I rarely have the radio on.
I got a universal rubber ducky from Advance Auto. It is female, but I have a M6 1.0 bolt that I cut the head off of, ground it down to correct length, and loctited it in place. Thinking back, it is possible that putting the cover on broke it. I sure hope so.
I had mine break also. Found the walmart antenna had poor reception. I instaled an antenna from an auto. The majority of all cars and trucks use the same stanless steel antenna that works great, same leangth and will not break. It has a smooth shank about 3/4 inch ,just cut a 6M thread on it and your in buisiness. I went to our local dump and out of 5 vehicles found 3 perfect antennas. Best deal no charge, works great and looks like original and will never have to replace it again.
Roger
2012 RT Limited
Vertika Floor boards
Painted rear fender & dash
Carbon fiber panels
Utopia back rest
Baker air wings
Elka shocks and relocaters
CB radio
ISO hand grips
Tric LED fender light
Turn signal lights in mirrors
Roger
Hey, I like that idea. I'm running the walmart shorty and the reception isn't good...downside of living in the sticks. When I hit the boneyard again I'll grab a steel antenna.
Eric
YNC(SS) (Retired) - U. S. Navy Submarines
2014 RT-S Cognac
3 seadoo's,CBR250R, Suzi GT750 waterbuffalo's x4, Rebel 250, MB5, '84 Alfa Spider, '97 Jeep TJ, '93 Saab C900CVT, '99 SLK230, '65 Mustang, '59 Fairlane, '48 Ford 8n
