Tire has gone missing
It looks like the Kumho ECASTA AST 225/50r15 is no longer available anywhere. I've looked all over the web and no one has it in stock. Even tire discount, the guys with the $81 and free shipping are out of stock.
I'm grounded, I need a new rear tire. What are my other options. I don't want something I need to change in 8k to 10k miles like the factory Kenda.
I had run 16500 miles on my last Falken and still good for another 2000 miles when I replace that tire. The best choice for tire replacement is 215-60/R15. Lot of choices in this size.
Now, I have a Michelin HydroEdge and it's a very good tire on wet or dry pavement.
KUMHO
THEY STOPPED THE MANUFACTURING OF THIS SIZE, and many others...
I EMAILED THE KUMHO PEOPLE LAST WEEK TO ASK THEM TO AGAIN START MANUFACTURING THIS SIZE FOR US SPYD3R RIDERS....
HAVEN'T HEARD "WORD 1" FROM THEM YET.....
KEEP LOOKING, SOME PEOPLE SAY THERE ARE STILL SOME AVAILABLE, BUT THEY ARE GETTING TO BE FEW AND FAR BETWEEN....
DAN P
EASLEY, SC
SPYD3R
I guess that I'd better wear my Kenda out soon, while I still know where there's a few Kumhos on ice...
check with SpYderpop's a site sponsor.
2011 RT LTD /MODS: Seal Floorboards, Elkas, SpyderPops Bump Skid and Block off plate, HMT Brake light, BajaRon's sway bar, Heim Links, Diamond R's passenger armrest, Utopia driver backrest
I just now found it on discounttiredirect.com and it did not show out of stock...
220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
Little checking..!!
there are no end to tires used and reviewed here. Kumhos are not the only other ones. Dig a little deeper and you will find others. There was a post earlier giving you the part number for the long lasting Kendas. I got 22,000 out of mine so if you get the 2012 on back kendas you will do well...
2012 RS sm5
205/60-15 is very close to OEM
Using this calculator I've been running 205's rather than 215 as its a bit closer to OEM size. On my third 205; two on previous '11 Rt and now one on the '14. Like 215, lots of choices.
http://www.tacomaworld.com/forum/tirecalc.php
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
SpyderLovers Sponsor
I have a brand new Toyo Proxes that I can sell you. PM me if you want it.
Thanks Ron, Just a few minutes too late.
Well it looks like the MAXXIS - MA-Z4S VICTRA 225/50-15 95V has now been discontinued as well. The 225/50-15 size is quickly becoming extinct. So, I decided to make the size change and ordered the Michelin HydroEdge Radial Tire - 215/60R15 93T from Amazon.
if you drop down to a 205 you can pick up the Kumo for $79
http://www.discounttiredirect.com/di...0&rd=15&cs=205
Is anybody using general altimax hp 215/60/15 I like the tread for the rear I am thinking the same for the front 185/60/14
I have the Altimax on the front. ~6k miles and they are great. Handle very well and show no signs of wear. I run them at 22 psi.
I have the Altimax HP 185's on the front, they fit fine and handle well, using a 215/60/15 on the rear but it's a Michelin Primacy. No nanny problems and the speedometer is right on.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
New tire arrived today.
Now to get it installed. I'll need to check the service manual to see how hard it's going to be to remove and replace the rear wheel from the Spyder.
PRAY TELL WHERE?
I HAVE LOOKED HIGH AND LOW WITH NO LUCK AT ALL.
