lovers web sight
The spyder sight seems to be off line a lot lately. Is it the site or my computer?
May want to check your 'puter ... I'm on practically daily, even while at work.
I am on it every day , if it is at work , they are bocking it
Looks like..!!
it's at your end. Site has been working fine...
Easy sailing in Hinterland
Nothing but cool breezes and blue sky's right here.
Clear your computer cookies and memory cache.
But did you know, about those amazing Sun flares today?
Ah, well let's just say there are going to be big Aurora Borealis this evening, for many.
Enjoy the free light show in the sky, all who get to enjoy its brilliance...
Chas
Might be related to the RT issue!!
been working fine here everyday
I think it might be some of the internet system between you and SL. The other night I had trouble accessing not only SL, but other distant sites as well. But a local TV station site came in OK on Chrome, but not on Firefox which I use most all the time. When I finally got reconnected to SL there were comments that had been posted while I couldn't connect, so obviously it was not SL that was the problem. At least not 100%.
I don't know, but I kind of think if one of the communication links your local ISP is using half way across the country goes bad, it might take the internet backbone servers awhile to establish an alternate route.
When you have trouble connecting to SL what about other sites? Are they all unreachable? If so, then your local ISP may be the problem. Try pinging SL. Sometimes the connection exists but the browser communication fails. Also, if you have wired cable internet you might be seeing saturation of the local cable link. In other words there is a high possibility that your problem is not your computer nor SL, but the system in between.
SpyderLovers Sponsor
Everything is under control, control, control....
If you can get to other websites, but not to Spyderlovers, check your DNS settings. I was using the DNS servers provided by Time Warner Cable, and had some problems. I changed all my settings to use Google DNS servers, and haven't had an issue since.
lovers web site
This may help when you're not sure if the problem is at your end or down in general.
http://www.downforeveryoneorjustme.com/
I've wondered sometimes and this set my mind at ease. Hope this helps. Have a good one.
That's It
Seriously...
I wonder if the Solar Flare eruptions, that will be kicking the snot ouf of our Planet's Magnetic Field; might have a hand in this?
Wondered the same thing last night when I was reading about the flares!
All's well that ends well
Still sailing on smooth water here. Even if the Sun does wave hello.
No Aurora Borealis was witnessed at all, checking throughout the darkest part of the day-night.
Clear your cache and cookies, turn off, turn on and get happy...
Chas
do you use FireFox?
This seems the most probable. I can get other sites. I tried at 8:30 am my time no luck and kept trying
through out the day, no luck. Then around 4:30 pm it showed up. Oh well thanks for all the input
If you have a smartphone try accessing SL with it when you can't with your PC. Or go to a coffee shop with a laptop and try. They undoubtedly use entirely different routing to get to SL. If you can get on it w/ the phone or at a different location, but not the PC then maybe it's time to try the DNS change noted above.
