Pain in my hands..
Ive own my Spyder for about 6mth and I am experiencing alot of pain in my hands. This happens at a speed of 70mph or higher. My hands go numb and the throbbing from the vibration is very painful. I changed my hand grips but nothing helps. Any suggestions...
A good set of antivibration riding gloves will help.
Ryde as if your life depends on it,
because it does !! Ryde Safe!
Vietnam 67-69
The angle of your hand/wrist to the bar may be the cause. Try one of thee new handlebars that adjusts that angle. I would check with dealer to see if you can see or try one out as installed on another model before buying. But people out there with the variable angle handlebar- please comment!
2012 Can Am spyder RT: RED! Widow pegs with kuraykyn mounts, ride on sealant in all tires, stebel nautilus air horn, ELKA shocks, Ultimate saddle & driver backrest, digital clock & oil pressure gauge (replaced OEM gauges), xenon lights all around, Custom dynamics brake light, SEAL pup floor boards, Baja ron sway bar, chain guard, bump skid & block off plate (all from spyderpops), Baker air wings, Custom Dynamics turn signals & fender lights, custom paint job (hot rod flames)
I would have the front tires balanced and the drive belt tension checked
Some people have had success with Shock Tec Gloves or stay under 70 lol
Grip puppies ?
smooth Spyder belt tensioner ?
Hope you find a cure , numb hands are awfull on a bike , I used to suffer a lot back in the day on GSXRs and Fireblades etc.
Good luck .
I have put on grip buddies. It helped a lot and makes it easier to grip.
4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
Hey Lady J! It could be a combination of things. High frequency vibration and
hand/wrist position on the bars. You need to get this addressed asap as it could develop
into Reynauds Syndrome and that is a difficult thing to get shot of. I had it 30 years back and
it wasn't fun!
among other suggestions. flex your hands every now and then.
addrd
TRIC led (SL sponsor) has soft gip add on.
into Renauds Syndrome and that is a difficult thing to get shot of. I had it 30 years back and
it wasn't fun!
Just read up on that a bit, doesn't sound any fun.
I have a $10 wrist rest (xtra wide) on my throttle, and a grip puppy on the other side - that combo just works for me. Then there's cruise control for the long haul...
2014 RT SE6 Rider
X - Honda Rider
X - RT S driver
X - RS driver
Lifetime VFW Member
i SAW THESE
knuckles
ARE YOUR KNUCKLES 'WHITE' AT THAT SPEED.....?
YOUR 'GRIP' MAY NEED ADJUSTING....
MOgang Member
DriftersWay is a good start.
The next step for me would be what Eagle1 stated. A good pair of gloves with gel inserts in the palm. Harley makes my favorite.
If the above doesn't help your hands, you can put weights in the handlebars. It helps deaden the vibration. Can't remember the company that makes them, maybe someone knows who they are.
Joy
Very Happy Ryder... '09 Phantom and a '15 F3-S
If you don't slow down, they can't catch you..
If you don't give up, they can't win.
What a long strange journey its been.
SpyderLovers Sponsor
Ride at 69 mph or less
Best bang for the buck... Had them on my last 4 bikes...
http://www.originalbeemerbuddies.com/
I'll go out on the limb here and say see your doctor. I'm not saying that because I'm trying to be a wise a$$; but, it sounds like you are having excruciating pain and not just simple numbness.
it wasn't fun!
As far as I know, Raynaud's Syndrome is related to cold weather or when someone is under stress. At least that's what the medical texts from school say, that I still have. I also stayed at the Holiday Inn last night; so, you can take what I say with a grain of salt.
can't say my hands hurt, but they did get some numbness. switched grips out for iso grips and no longer have the problem. also had alignment and have the smoothspyder belt tensioner! no vibes now. even done 500 mile days.
I had something similar going on with my right hand . . . I had some old SCUBA wet suit material (closed cell neoprene) and made a set of grips from it . . . the problem has never reoccurred.
"Topper" is my Pearl White 2013 RT-LTD
Professional Retiree - liked it so much when I retired from the USAF, that I started another career so I could do it again!
Happy to be a member of the Maryland Spyder Web - find us at
http://www.meetup.com/MarylandSpyderWeb/
I bought a pair of thick foam grip covers from TricLED - one of our supporting vendors. I love these things. (Scroll half way down on this link.)
However, I agree with those who suggested checking the balance on the front tires.
I had the same problem. I fixed it with a pair of Cramp Busters. Only $8.00 each.
Dan
2012 Viper Red Rt
upgrades:
Baja Ron's Anti-Sway
Diamond-R Arm Rests
Gloriders
High mount brake light
chrome front fender garnish
Bad Boy Horn
Chrome Deflector Rack
Chrome Scuff Nose Accent
Handlebar Grip Fringe
Gremlin Bells
What's the vibration your getting. That should be the first problem addressed. I get a little belt vibration.
Not significant. Can run 100 plus no vibration. Keep a lite grip
Start with the simplist possible solution first...
GRIP PUPPIES AND "BIONIC' MOTORCYCLE GLOVES DO IT FOR ME
Originally Posted by Mike X
Grip puppies ?
Good luck .
I'VE HAD THAT VIBRATION ISSUE ALL MY LIFE, AND HAVE FOUND THAT GRIP PUPPIES AND BIONIC M/C GLOVES SOLVE THE PROBLEM. GOOD LUCK WITH IT.
RIDE SAFE,
CAPNCRUNCH : =)
