Results 1 to 9 of 9
    Invalid Emails
    Jan 2008
    Deltona Fl.
    Default sync throttle body
    Has anybody done a sync on there throttle body yet. If so what procedure did you use. Did you do it without having to hook up B U D S sys?
    Mod Maniac ataDude's Avatar
    May 2008
    North Texas
    Quote Originally Posted by spyder13 View Post
    Yepper, done it twice. Once with a TwinMax and then, as a check a week later, with a new Morgan CarbTune... only because I couldn't find my mercury gauge.
    I was looking for a solution to an uneven idle... that BUDS said was just dandy.
    The factory settings were right on the mark. Be sure and read the service manual section (starting on page 251) about where to connect the vaccum hoses and how to electrically disconnect the MAPS sensor.
    You can do it all from the left side without removing the air filter box... but it sure is easier if you do remove the entire box.
    ata = allergic to asphalt
    My mods: https://www.spyderlovers.com/forums/...ead.php?t=5753
    There are two kinds of people: (1) those who can read, reason and apply the experiences of others; and (2) those who just have to pee on the electric fence. ataDude, 2009
    My Spyder:
    Active Member DragonSpyder's Avatar
    Aug 2008
    So, what was the fix for the uneven idle?
    Invalid Emails
    Jan 2008
    Deltona Fl.
    atadude what mods do you have on your spyder?
    May 2008
    North Texas
    Heh... click here: http://www.spyderlovers.com/forums/s...ead.php?t=5753
    If you're talking about performance mods, then not much except for the pipe. I like my warranty.
    My Spyder:
    Active Member Spyderjuice's Avatar
    Aug 2008
    High Point, North Carolina
    Quote Originally Posted by ataDude View Post
    Now, don't get me wrong, but... 93 octane gas. No bull. It's now at +/- 50, not +/- 200.
    No comments about gas, PLEASE, from the peanut gallery! I wouldn't believe it, either, if it wasn't me.
    Juice
    Happy owner of 2014 White RTS - SE6
    Invalid Emails
    Jan 2008
    Deltona Fl.
    Sync the throttle body again today after i cleaned my morgan carb tune. Works ok now and sync was easy. I have an idle 1400 to 1350 rpm.
    May 2008
    North Texas
    How far was yours off?
    My Spyder:
    Invalid Emails
    Jan 2008
    Deltona Fl.
    wasn't that far off. Just like to know where all my stuff is at. Auto mechanic you now how it is. Checked my own valve clearance to know where that was too
