Results 1 to 15 of 15
    Registered Users mtdoragary's Avatar
    Jul 2010
    KILLEN, AL
    Default Front trunk light?
    Brochure says my Limited is supposed to have front trunk light. Can't find one. Also says it comes with comfort seat. Didn't. What ELSE was exaggerated?
    3:16
    SoFlo
    The light is most likely there and behind the trunk liner. Have a look at the forward left corner of the trunk liner for a slot that the light pokes through.
    Worse case, peel the gasket up, and move the trunk liner back to have a look. Takes about one minute and you'll have it dialed in. Not sure why dealers don't verify the light is unobscured.
    As for the seat, there was talk of this months ago. Somehow I got the impression the RT Limited does come with an upgraded seat from the RT and RTs. Seems the call it a comfort seat. The catalog option seat is also called a comfort seat but is a different comfort seat. Who knows I may be totally wrong. It's been a while since this was talked about.
    The real missing item, and some have bitched and had it added for no $ was the electric release for the front trunk.
    Regardless, the sales literature explains that features may change without notice.
    All the best with it.
    PK
    SoFlo
    This is a copy from the RTL sales stuff. They used the words ultra-comfort which got confusing.
    This ultra-comfort touring saddle has exclusive embroidery and comes in different colors to complement the color of the vehicle for an amazing look.
    If this link works, it shows the available seat options and costs for each.
    http://can-am.brp.com/spyder/build-a...modelYear=2014
    Even the RTs could be misread.
    NEW TWO-TONE SEAT
    COMFORT AND STYLE
    This ultra-comfort touring saddle has an exclusive look with an eye-catching dual color scheme.
    PK
    Jul 2010
    KILLEN, AL
    Thanks; I agree on the electric front trunk latch. Mine doesn't release unless I press down on the lid while operating the key- a rather gymnastic move!
    3:16
    Jul 2010
    KILLEN, AL
    If there's a light, it's the best hidden light ever!
    3:16
    Left side, and up near the front...
    It's in a recess that you can feel (but NOT see...)
    Active Member Gundam's Avatar
    Singapore
    The light is there.... the key must be in the 'ON' position and frunk lid open to work....
    Active Member dadof4's Avatar
    Apr 2010
    Ontario, NY
    It took me a year to find the frunk light on my 2010 RT. Find a night with no moonlight and a spot where there is absolutely no external light and you may find it. I'm not sure but I think the engine had to be running or the key to be in the on position for it to work.
    2014 RT Limited - Black / Currant
    Quote Originally Posted by mtdoragary View Post
    I'm just the reverse! I spent the money to install the electric release on my RT (base models don't come with it) and have found it to have been pretty much a total waste of money. I almost never need to open the frunk when the ignition is on, so it's a pain to turn the ignition on and then off just to open the frunk. If I had known that the key can be pushed and turned to open either the seat or frunk even when the bike is running, I wouldn't have bothered.
    You should be able to adjust the latch so that the lid will pop free when the key is turned. Mine does.
    Jun 2010
    Las Vegas
    The trunk light is a joke, it is about 1/2 an LED. BRP has used the word "comfort" to describe all of their seats. I guess calling one "non-comfort" might not have sounded good.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Quote Originally Posted by WasWinger View Post
    If you want to remove it, and get it out of your garage... PM me!
    Nov 2012
    North Las Vegas, NV
    Default Frunk light
    It took me two years to find this light. I was doing some work on the bike before our July vacation and had the key on with the frunk lid open and I saw the light! Front left if you are sitting on the seat.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    May 2013
    Edmonton Alberta, Canada
    PK
    Low and behold, I've seen the Light!
    Thanks for pointing out it just might be behind the liner!
    2014 RT-Ltd , Cognac
    Very Active Member bruiser's Avatar
    Eastern North Carolina
    On 2010 RTs the engine had to be running to open the trunk with the switch. 2011 and above, just need the key on. The light is useless. I have word that an aftermarket light is in R&D.
    USAF '69-'89 E7
    Thailand/Vietnam 1972
    Member: Royal Order of Rat Bastards
    Kewlmetal sells (or at least sold...) A real nice LED strip, that you could wire into the system...
