Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
  1. #26
    Jun 2014
    ny
    i must be lucky with 4k on my kenda's they still look very very good. i think i will get about 9k or 10k out them before i need to replace them & will probably stay with the factory kenda
  2. #27
    Active Member sledmaster's Avatar
    Sep 2007
    Minnesota
    Quote Originally Posted by KX5062 View Post
    Thanks for answering my questions. The figure of a 7" rim, is that what the book says, or is it a real world measurement? Also, when you pull the front tires, can you measure the rim there also? It would nice to add to the knowledge base. Also, keeps us posted on your observations with the new fronts.
    7" rim is what the book says, I am sure we can get a measurement on that.
    I find it encouraging that those who have used the narrower profile tires are reporting less center section wear. Maybe no silver bullet here, but if we keep pressures down, go with a better carcass tire that will hold its shape better, and go with a slightly narrower profile to reduce the rim effect then maybe we have a workable solution. Let's keep gathering data on this.
    With all of the different tire wear reports, we should remember all of the factors that go into how long a rear tire lasts. How the user accelerates and brakes, the road surface, the average speed, the tire construction, load on the vehicle, preload settings, air pressure, temperature, many factors. How else could we see such variations in how long the exact same tire lasts?
    2021 RT Limited - Deep Marsala Red – 4,200 miles
    2013 ST-S SE-5 - Circuit Yellow – 56,000 miles
    2015 F3-S SM-6
    - Can-Am Red Solid Gloss – 2,000 miles - SOLD
    2008 GS SM-5 Premier Edition #659
    - Full Moon – 34,000 miles - SOLD
    2008 GS SM-5 Premier Edition #006
    - Full Moon – 34,800 miles - SOLD
  3. #28
    Invalid Emails
    Apr 2014
    Northwood NH
    Here's my 215/60/15 Hydroedge at 4000 miles and as you can see the wear is pretty even across the tire with 28 psi
  4. #29
    Very Active Member billrob71's Avatar
    Jun 2013
    Delaware
    As much as I like to spin the rear tire can we just do a retread while it's on the bike
    Thanks for the update any improvement is a plus THANKS BRP for listening to us
    Bill
    2013 RSS Neutron Green
    BRP HID's and Fogs
    Custom Belt Tension
    2014 side panels
    HMF Exhaust
    K&N air filter
    Bajaron sway bar and links
  5. #30
    Jun 2014
    Byhalia, MS
    Default 2014 Spyder RT What Michelin did you switch to?
    Quote Originally Posted by sddinnh View Post
    I'm glad that they reacted, but I've already switched to Michelin. Now if we could them to talk about a stiffer sidewall on the fronts
    What Michelin tire did you switch to? I could not find the 225 50 r15 in a Michelin.
    Thanks!
    Dshack7
  6. #31
    Very Active Member AbNormy's Avatar
    Apr 2012
    SW Austin
    When I replaced my Hydroedge after about 20k miles I couldn't find another so I got a Defender I'm pretty happy with
    2012 RT A&C bought new 42312 sold July 2018 56k miles currently driving a 2014 RTSE6 LTD bought October 2018 w 6800 miles nicely farkled
    2014 RT SE6 LTD , White
  7. #32
    Very Active Member Orange Spyder Man's Avatar
    Sep 2014
    3rd ROCK FROM THE SUN !
    I won't ever buy another Kenda... won't put a 2 ply tire on my Spyder... 2 ply tires are for lawn mowers & wheel barrows.. surely not a vehicle that runs down the highway at 60 + MPH...
    osm
  8. #33
    Very Active Member finless's Avatar
    May 2013
    Stanton, ca
    Quote Originally Posted by AbNormy View Post
    I really thing the Defender is not a good rear tire because the tread is one sided and made for a car.
    You can clearly see in the picture the centerline of the tread is off to one side.
    2011 RT-S SM5 - Black
  9. #34
    Registered Users lookerjdc's Avatar
    Aug 2012
    Melbourne, Florida
    well good for them (finally)
    I only got around 6000 miles out of the rear tire on my 2014 RT before I had to replace it, and I put a Kuhmo on mine also
    1. it is what it is - 2014 Black RT-S - Baja Ron Anti-Sway bar, lots of LEDs, Spyderpops Skid Plate, Twisted Sister HID Driving Lights, Tricled 2nd, 3rd & 4th brake lights, F4 Customs vented windshield, Lamonster highway pegs, Ultimate Tall Boy seat, Utopia backrest
  10. #35
    Prior to buying my 2014, I had received 13K - 15K mileage on the OEM rear tires. The 2011 now has 16,500K, but will be replaced when I take it in for beginning of the season servicing.
    Last summer, I had to replace the rear tire on my 2014 RT at about 8,900 miles. This was the lowest rear tire mileage I have experienced so far. Compared to a lot of reports, I did better than an lot of owners who replaced tires between 4.5K and 6K miles.
    When I replaced my rear tire, I was told the part number had been changed and that the new tire I received was the "old" version of the tire. I reported on this at the time. Did I get a "real" old version of the tire? I will find out this summer.
