Results 1 to 20 of 20
    Registered Users 3 Wheel Addict's Avatar
    Sep 2013
    Southwest Ohio
    Default Nother problem with the 14??
    This is starting to happen more often now.... starting the spyder either hot or cold does not matter, shifting into gear, engine stalls out like the clutch is not engaged. The bike tries to lurch forward and just stalls out as soon as you hit the shift button . It will restart and then be ok but it will do it again later. So far it has done it about 3 times a day for the last few days. No codes coming up. Anybody seen this??
    Sold my 14 RTS went back to 2 wheels.
    2014 Kawasaki Vaquero SE
    Jul 2014
    Helena Montana
    i have had this happen 2 times in the last week. 1st time was after 200 miles and a stop for gas. the next time was after only running about 10 minutes. Will always restart after so not sure.
    Invalid Emails
    Apr 2014
    Northwood NH
    Ditto for me. Happens occasionally but always starts in 1st if I keep my foot on the brake - no codes - Tech has no answer
    Active Member Princeau99's Avatar
    Apr 2014
    San Jose, CA.
    Default Just curious
    I have never seen this on my RTS se6. Is yours an sm6 or se6? Do you always start with foot on brake?
    2014 Pearl white RTS
    Default YEP
    Quote Originally Posted by sddinnh View Post
    ....My 14 RT just turned 5100 miles and this started happening just recently also................ANNNNNNNND the first wear bars on the rear tire are now beginning to show wear ......Mikeguyver
    Me too. About 4 times now.
    Mine'll do it every once in a while, just to get my attention...
    Foot on the brake, and thumb the starter again, and all is good!
    Jun 2011
    Near Lexington, NC
    I've had it happen a few times but its always caused by my
    trying to put it in gear quickly after starting before its had time to idle down.
    Give it a few seconds and see if that helps.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    I've found that technique, helps a lot!
    Mar 2013
    South East Wisconsin
    Default Mine does it as well after its warm
    and mostly when I put it in reverse. At least I'm not alone.
    Lets ride!!!!
    Sep 2013
    Southwest Ohio
    Mine is an se6, and I was thinking that maybe the oil pressure has something to do with it, maybe a little slow to release the clutch? Well I feel better that I'm not alone with this issue.
    Jun 2013
    queens ny
    what happens with mine is if i put it in neutral i sometimes find it shifts back to first gear. it happened over the weekend when i was up state.
    NO BIKE AT THIS TIME
    Default WELLLLLLLLLLLLLLLLLLLLLLLL!!!
    Quote Originally Posted by cuznjohn View Post
    .......That's your problem John..............stay DOWN STATE ... ....Mikeguyver
    Jul 2014
    United States
    Mine has not done it for a while. I am taking a little longer to shift and that seems to help. I also found that to get a softer shift into reverse you can go to first, then straight to reverse with no bump. So smooth you actually have to look to see if it's shifted. Neutral......not so much.
    Very Active Member Magdave's Avatar
    Jun 2013
    NE South Carolina
    Hmmm my 2013 doesn't do that the tranny works just fine and never stalls....just sayin' Sorry Bob just had to say it
    2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
    Jax Beach, Fl.
    Mine just did it twice today once going into 1st & once going into reverse. My engine was up to normal operating tempature each time. I have 1,950 miles on the motor now and this has never happened before.
    2014 RTL-SE6 Cognac (Current Love)
    2012 RTS-SE5 Pure Magnesium Metallic (Pre Loved)
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by A1A View Post
    Make sure you don't rush it. Even when already warmed up, the engine cranks up a hundred or two above idle. It takes a couple seconds or so for it to idle down. It will often stall when above the idle and occurs when we get in a big hurry.
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Nov 2013
    Oro Valley Arizona
    Same here but only when it's cold. Only 650 miles so I am at the learning curve. Yep that's right, got tired of the heat and gas fumes last week and traded the 2013 red viper in.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Jul 2014
    Mint Hill, NC
    With 1,075 miles no problems other than that clunk into R after a start -- warm or cold, doesn't matter. Thanks for the tip on shift to 1 first and then to R. Will try first thing tomorrow when I head to dealer to get Comfort Seat with defective stitching replaced.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Jun 2013
    NE South Carolina
    Quote Originally Posted by jaherbst View Post
    Jack
    What happened with the BRP Testing you were doing?
