Results 1 to 25 of 34
    Apr 2012
    Columbus, Ohio
    Default 2014 RT Limited / Body Roll
    Anyone had any issues with body roll on there 2014?
    Mine is in the dealer with what I thought was bad front tires. Front tires were changed out with new ones. The symptoms I thought was excessive vibrating of the front end at 40-50MPH. My dealer is calling it body roll. OK whatever. They are saying that BRP had issues with the stock shocks on the RT's. Anyone else experiencing this?
    After the tire replacement is still has "Body Roll".
    Kind of unsafe to be riding. I'm now growing somewhat concerned. New shocks from BRP hasn't arrived yet. I did go ahead and order Elka's 1 + R for the front. Machine only has 300 miles on it.
    Jul 2010
    KILLEN, AL
    Mine has excessive body roll too. Checking to see if Bilstein has shocks for it. Don't want sway bar because of added weight and harsher ride.
    Quote Originally Posted by R30SHIRE View Post
    Jun 2010
    Las Vegas
    Quote Originally Posted by mtdoragary View Post
    The BajaRon sway bar doesn't weigh a pound more than the stock bar. And it makes for a better ride not a harsher one.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Apr 2012
    Columbus, Ohio
    I installed Bajaron sway bars and that didn't help.
    Stupid question here...
    Are your tire pressures set correctly?
    If the pressures are low; they'll roll over on you!
    Apr 2012
    Columbus, Ohio
    Yes, tire pressures are correct. 19 fronts and 28 rear.
    Wheel bearings checked out ok. Front end feels like driving on ice.
    Houston
    You've got it backwards. Its stiffer shocks n springs that will yield a harsher ride, the sway bar only controls body roll or sway, does not effect spring rates or ride harshness.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Default Let's see..!!
    shocks and tire pressure will be the places to check. Now you mentioned vibration..was that fixed when they changed out the tires..?? Don't see where that would have anything to do with body roll. The other thing often overlooked is the rear shock, if not adjusted correctly it will allow the rear to lift throwing you into the curve thus body roll...
    Houston
    Didn't help what? Your original post was about front end vibration. That has nothing to do with body roll or sway. The sway bar has nothing to do with wheel balance which cause front end vibration. I KNOW the Bajaron bar helped reduce sway or body roll. There is simply no way it could not.
    Jun 2013
    queens ny
    i found my 14 would wonder, as i called it so i changed out the stock shocks to elkas and it feels better
    Apr 2012
    Columbus, Ohio
    After the new tires were installed the service manager said it helped some, he did say that he adjusted the rear shock setting in all positions and it yielded no difference.
    Houston
    Don't understand what you are trying to fix. This is the third completely different symptom you have described since the thread started. Now you say 'feels like driving on ice' Not really sure what you are trying to describe here, insufficient traction? tire skid? Lack of braking force available? Please give a better description of what it is you are having trouble with and someone here can likely help.
    If your dealer called wheel vibration 'body roll' you really need to stay away from that mechanic.....
    Apr 2012
    Columbus, Ohio
    No, same description. Front end play as in steering, body roll is in the front end.
    Active Member Princeau99's Avatar
    Apr 2014
    San Jose, CA.
    Default good to knoww
    On an RTS, do I want the display all the way up or down?
    Also I bumped the front up to 22 PSI and that seemed to help.
    2014 Pearl white RTS
    Apr 2012
    Columbus, Ohio
    Quote Originally Posted by Princeau99 View Post
    You referring to the rear shock pressure?
    Houston
    Still trying to understand what it is you are trying to correct. Steering play indicates something loose in the steering linkage, IE wander or directional control instability or a condition where moving the handlebars does not produce a corresponding change in direction. Body roll is completely different and has NOTHING to do with steering other than you experience it WHEN turning. IE the body rolls to the outside of the turn.
    Just taking a stab here with all the descriptions you have attempted, are you saying the front wheels and fenders vibrate or wobble at speed? This is completely tire and wheel balance or defect related if the bearings have already been checked and found not loose.
    Really trying to help here, I have a long line of experience in suspension design but its hard to offer help when you keep changing (with or without intent) the problem we are chasing. It just seems you are throwing words out there without understanding thier meaning or how they relate to various suspension components.
    Default SWAY CONTROL
    ....I made some brackets for the bottom attachment of the front shocks on my 2014 RT that increased the angle ( more up-right ) by 7 degree's and this appears to have helped the sway issue with mine.....I have no adjustment on my OEM shocks and haven't gone to RON's sway Bar yet......I'm not sure I have too................Mikeguyver
    I think that we're getting nowhere fast...
    Six folks talking about eleventeen different things; won't help the guy.
    Let's let jcthorne help him try to figure out what he's asking, and then we can see what might work to help the problems that he's having...
    Jun 2013
    queens ny
    Default bob
    remember when we met i told you that i was keeping quiet but i felt the bike was wondering around on me. well i think that is what he is talking about, i felt the bike was leaning and moving around on me in turns and with the elkas it fixed my problem. now with the wrong shocks on the bike it is a big change but it just bottomed out on me. so sunday the new right shocks will go on the bike and my bike should be set up just right.
    Active Member nhoj's Avatar
    Apr 2012
    Aurora Ontario, Canada
    ......I have no adjustment on my OEM shocks ...
    Try some spring rubbers. Worked nicely on my ST which also does not have adjustable shocks.
    Shock Spring Wedges
    Marilyn 2023 RTL Red
    John 2023 RTL Black
    previous:
    2015 RTS SE6 Red
    2015 F3S SE6 Silver
    2011 RT SM5 Silver
    2013 STS SM5 Silver
    "common sense will prevail....but we see no sign of that"
    This is a crap shoot. Sounds like the problem may be the dealership calling this 'Body Roll'. If the sway bar upgrade didn't help, then it can't be body roll. Has to be something else.
    The most important aspect of fixing anything is finding the cause. Sounds like so far the problem has alluded the dealership and they are simply throwing parts at it hoping to hit on the fix.
    Luck beats skill every time. But ONLY good luck...
    Hope they find the problem soon. And please let us know what the final outcome is.
    This is a new one on me. I'll send you a bar kit. If you like it you can pay me. If you don't I just ask that you agree to return it.
    Very Active Member kinggeek's Avatar
    Jun 2011
    Cincinnati, OH
    Now that's customer service! I need oil filters for my NEW ST-S. WILL email you soon.
    Kinggeek
    Mandeville,LA
    VERY HAPPY Spyder Ryder!
    Where have we been on the Spyder? See below:
    Can-Am Spyder ST-S SE5 in Congac
    Default OUT OF CONTEXT
    Quote Originally Posted by nhoj View Post
    Shock Spring Wedges
    .......Thanks for the info ......But as I stated in the rest of my post......I think the BRACKETS have solved the issue ...Mikeguyver.....
