Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 51
  1. #26
    Very Active Member cruisinTX's Avatar
    Mar 2015
    Fritch, Tx
    I probably don't correctly grasp your physical post surgery situation but if you bring the ends of both bars closer toward you (I read that "back") you are also going to bring the ends of the bars closer to each other (shortening the bar wing span so to speak) which would reduce the stretch of your wing span. I have never played with my bars to see the total adjustment range because I've always made changes in small increments to get the fit just right for me.
    I need them closer to each other but not closer to me. Closer to me (my body) causes a more upright seating position which I cannot do. Having them closer to each other relieves the stretch/reach required that is causing muscle tension between my shoulder-blades. The ideal configuration for me (in my mind----scary place; I know) would be closer together and about an inch or two forward of where the stock bars are now.
    2014 RT Limited , pewter (magnesium?)
  2. #27
    May 2013
    Stanton, ca
    Quote Originally Posted by cruisinTX View Post
    Bob, I've seen the Tri-Axis bars and it appears as though the only way to get the bars closer is to also have them move back. Due to my own post surgical back situation, I cannot do that. It puts too much vertical pressure on my lower back. Appreciate the suggestion and video just the same though.
    I'm wondering if there were enough demand, BRP might consider width choices in handlebars; maybe even something that is a retro-fit. I'm not a real big guy (5'4") and the wide bars cause a lot of fatigue in the middle of my back and both shoulders due to my short "wing span".
    Because of the "composit" nature of the RT handle bars, I doubt BRP or anyone really would make alternative handlebars.
    Bob
    2011 RT-S SM5 - Black
  3. #28
    Mar 2015
    Fritch, Tx
    Quote Originally Posted by finless View Post
    Bob
    You are probably right; but I do have an alternative plan for adding a new place to rest my hands, shoulders, back while on the open road. I'm already working out details --- in my mind.
  4. #29
    Jul 2014
    Mint Hill, NC
    Understand the problem now. I agree with Bob, if you found someone who would make the bar covers they would probably be very expensive.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
  5. #30
    Idaho
    As I understand it you need to lean forward some to keep your back comfortable and the spread of your arms is what you need to reduce. You're correct in that bringing the grips closer together on the Tri-axis bar brings them rearward also. But not only that but the angle of the grips with respect to the bike centerline changes so you have to turn your hands outward. That could cause your wrists be uncomfortable.
    Be aware that if you bring your hands in closer to the pivot point of the handlebars you will increase the amount of push and pull required to steer. You know, the longer the lever the less the force required. Bringing the grips in toward the center 3" would probably be way too much.
    I just looked at the stock handlebar center piece I took off. IMO any sort of inward adjustment just isn't practical with the stock handlebar nor with the Tri-axis bar. Your best bet would be to have a custom center piece built by a machinist/welder. That might even cost less than the Tri-axis handlebar. The hand grips are on tubes that are easily separated from the stock centerpiece so can be fastened to any custom center piece. Probably wouldn't look quite as good as the OEM, but sometimes beauty has to take second place to function. I also would be hesitant to try to modify the stock centerpiece since it is made of some die-cast metal that probably cannot be readily cut and welded and still be absolutely safe.
    2014 Copper RTS
  6. #31
    Very Active Member ahh-cool's Avatar
    Jun 2014
    south florida
    I read this post and wonder how do you know that you need a 1" adjustment?
    My neck has been bothering me lately on my rides. I just figured it was stress
  7. #32
    Apr 2017
    North Central Florida
    Won't help much for riding in traffic but while "cruising", try holding the "bars" just to the INSIDE of the grip clusters.
  8. #33
    Apr 2017
    Back to the original question:
    This was asked WAY back there and never answered, or I didn't see it:
    Couldn't a "simple" riser be added at the center piece ?
    Since you have one off maybe you could venture an educated guess.
  9. #34
    Sep 2009
    La Valle, WI
    Look on ebay for black ones that have a best offer. I got mine 1 year ago for 400.00 with free shipping still new in box. They were somewhere in California. A lot are just sitting on shelf's and they just want them gone. I did mine myself and I did not see of anyway you could add risers.
    2018 F3 Limited , Oxford Blue
  10. #35
    Idaho
    Quote Originally Posted by Easy Rider View Post
    It probably could be. Here's a pic of the bottom side of the center piece. The mounting plate on the top of the steering shaft is flat. There might be a problem with the ignition wires and the seat and frunk cables getting tight. The ignition switch mounts where you see the two holes on the flat piece.
    2014 Copper RTS
  11. #36
    Mar 2015
    Fritch, Tx
    That is what I'm thinking but kind of opposite of IdahoMtnSpyder's goal. Like a set of bars that allow for a place just slightly forward and moved in to provide a spot to rest your hands but that would not have and controls on them. They would also need to be out of the way of all other controls and strong enough to steer the bike to full stop to stop positions; although the primary purpose would be as a "relief position" when cruising down the road on cruise control.
    I already frequently rest my hands on the blanks spots just to the inside of the controls. While that does help some, it is not as comfortable as I would like. I'm thinking an add-on that would nearly or completely duplicate the OEM grips in a different position would be much better.
    Now, I'm not an artist of any kind (especially with a computer) but where the blue lines are in the picture, try imagine a set of "handlebars" attached at the bottom and supported up the incline part of the original bars (possibly attached at a couple of points on the front side of the angled part) and extending maybe 1" to 1.5" above and in front of the controls on each side. There would only be some comfortable grips on them but no attempt to move controls. This is what I'm attempting to fabricate, but trying to do so in a way that does not alter the original bars in any way and is easily removable if need be.
  12. #37
    Apr 2017
    You probably won't like my next comment.
    I think the time and effort and $$$ expended on that would WAY exceed it's real value.
    But I can't really gauge YOUR degree of discomfort.
    I think a lot of people these days, younger ones mostly, spend WAY too much time worrying about things not being EXACTLY as they want them.
    I don't really blame them because their parent's generation taught them that they can have anything they want, exactly as they want and immediately if not sooner. BAD mistake. Hard to fix.
  13. #38
    Idaho
    I'm pretty sure I understand what you're wanting to do, but two questions. Would you be comfortable having your hands and arms raised above the current level as they would need to be to give you clearance between the new grips and the handlebar? And second, do you think you would have your hands up there and not at the controls enough of the time to justify doing this? If the biggest share of your riding is out on the open road using cruise control then I can see this idea as a viable possibility. But, if much of your riding is around city streets or curvy roads which require operating the throttle and shift paddle, then I would be skeptical.
    2014 Copper RTS
  14. #39
    Active Member scarecrow's Avatar
    Sep 2013
    largo, florida
    I'm 6'2". I have mine set full out and full foward. My tech calls it "moto x drag bars". Just gives me more room to move around as we ride two up alot. It's a stretch for some, but comfortable to me as I have a long reach.
    2014 RTS , Cognac
  15. #40
    Mar 2015
    Fritch, Tx
    I appreciate the (mis)conception of me being young; especially at my age (63). I do want things exactly the way I want, but am not in a huge hurry to get it right away. As for expending a lot time and effort, it's sort of a hobby of mine to fabricate things I need, but I rarely spend a lot of money on my projects. I have fun being innovative and when something does not work out exactly as I intended, I still try to have learned from the process. It took at least six versions of building a custom seat to get one just right on my sport-touring bike several years ago. While I spent a lot of time and effort on it but very little money, I also learned a lot about what makes a good seat and what does not; both in type of material and shape. In the end the experience helped me to build my next two seats for different bikes on the first try and they turned out perfect.
  16. #41
    Idaho
    I was just looking at the handlebar center piece. You mentioned putting your hands on the straight section inside of the controls but it's not completely comfortable. Is that because of how large those sections are? If you want to grip even closer to the center look at putting a piece of pipe between them. Cut the ends of the pipe at the proper angle and then bolt it to the handlebar. If the spread of hands gripping there is enough, I think you could fit a pipe piece in there without too much work. The only modification to the OEM handlebar would be a couple of holes for bolts.
    2014 Copper RTS
  17. #42
    Mar 2015
    Fritch, Tx
    yeah, I've been eye-ballin' and old set of bicycle handle bars as an option for attaching sort of like you suggest. the way they are designed, it might be feasible to mount them in a way they would end up just about the way I have the horizontal part of my graphic above. I'm looking at a way to do it without drilling any holes though.
  18. #43
    Idaho
    In my judgment a couple of 1/4" or 5/16" holes would be worth the improved comfort level! And whenever you get rid of the Spyder you can plug them with push in plastic plugs or seal them up with black silicone rubber. Besides, the way I look at such things, when it's time to get rid of the Spyder it will be old enough that a pristine condition will not be expected and won't improve selling or trade in value all that much anyway! But, that's just me. I live by the philosophy that I own my Spyder to ride, not show off! Whenever showing off interferes with riding enjoyment, showing off always loses!
    2014 Copper RTS
  19. #44
    Mar 2015
    Fritch, Tx
    I totally agree with the "it's my bike and I'll do what I want to it," philosophy. I'm just wanting to make sure there is absolutely nothing a dealer might use to say I voided the extended warranty. Have I mentioned I trust bike dealers about as much as I do used car salesmen, politicians and lawyers? So far two out of three BRP/Can Am dealers I have dealt with have proven to me they have very little real concern for customer satisfaction or are totally heartless with price gouging.
    I've actually formed a pretty good plan now that will allow very solid attachment without drilling holes in any part of the bike.
    As for farkles and showing off; that's not my cup-O-tea. I am an old school BMW guy who's primary attitude about bikes is "function over form." Fancy lighting, colorful wraps, etc. mean absolutely nothing to me. On the resale end of the deal, I typically don't worry much about that either; case/s in point--I own a 1984 Jeep Scrambler that I bought new in September of 1983. It now has over 250K miles on it and needs just a little TLC to be running again. Also in the 4-wheeled stable is a 2006 VW Jetta TDI (also bought new) with over 300K on it. Gotta get your money's worth out of things ya know.
  20. #45
    Apr 2017
    Good. That's quite different from expecting someone ELSE to fix everything that you don't like........and getting frustrated when that doesn't happen.
  21. #46
    Apr 2017
    How about a couple of pieces of stout rope, one tied to each end of the bars........so then you could ride it like a horse.
    (Sorry, couldn't resist.)
  22. #47
    Mar 2015
    Fritch, Tx
    oooooooh! mmmmmmmaybe not
  23. #48
    May 2013
    Stanton, ca
    Ropes did you say?
    Bob
  24. #49
    Mar 2015
    Fritch, Tx
  25. #50
    Jun 2014
    south florida
    What about new grips?
    I was thinking that might stop some of the stress in our shoulders and neck
