Results 1 to 14 of 14
    Jul 2010
    Pittsburgh, PA
    Question anyone notice two brothers exhaust bracket rubbing the fender mount on ST?
    anyone else getting the rear fender bracket notched by the bracket on for the TWO BROTHERS exhaust?
    just noticed that there is a square projection that rubs against the rear wheel fender bracket enough that it took about a mm notch in the fender bracket from hitting it.
    Mar 2014
    Waiuku, New Zealand
    Default No
    Just had a quick look at mine and it's no where near the rear fender bracket.
    A picture of yours may help.
    Jul 2010
    Pittsburgh, PA
    Jul 2010
    Pittsburgh, PA
    Its the tab on the backside of the bracket
    Jul 2010
    Pittsburgh, PA
    Anyone else see this happening. I assume the bracket is from the two brothers exhaust.
    Unless it's part of the isci hands brake kit
    sent from my Amazon Kindle Fire 8.9 HDX Tablet
    Invalid Emails
    Jul 2013
    Wayne, NJ
    Default Two Brothers Single Sound?
    I've been trying to decide which exhaust to buy. Love the sound of the Dual Two Bros but of course will not work with side bags. I've heard the Dual system and love it. But can not find any sound clips of the "single" exhaust. Any chance of uploading a sound clip? Also, how do you like it?
    Thanks,
    333Club
    Jul 2011
    Kresgeville PA
    Default anyone notice two brothers exhaust bracket rubbing the fender mount on ST?
    The bracket is mounted incorrect and needs moved to the outside of the cast piece. The tab should be under the oem cast piece. The tab keeps the bracket from rotating on the bolt.
    Jul 2010
    Pittsburgh, PA
    Thanks! Can you take a quick picture of how is supposed to be?
    Jul 2011
    Kresgeville PA
    Jul 2013
    North Bergen
    Quote Originally Posted by clueless View Post
    I have the dual from them no issues at all.....
    Jul 2010
    Pittsburgh, PA
    Thumbs up
    Thanks Jesse for the picture... will unbolt and move the bracket to the OTHER side of the cast support...
    Jul 2011
    Kresgeville PA
    Also there should be a aluminum washer that came with the bracket that spaces it out from the cast piece.
    Jul 2010
    Pittsburgh, PA
    Looks like it was installed before they had the kinks figured out on the STS. I see online the latest instructions from Two Brothers for the ST models says there is a spacer they ship that inserts into the existing spacer. I tried removing the OEM spacer on the STS but it stuck in place. On the install pics it looks like it is removable and you are left with the cast piece only that you insert the supplied spacer.
    hmmm ....
    Quote Originally Posted by Jesse View Post
    Jul 2010
    Pittsburgh, PA
    Looked on the parts listing and the bushing is removable.
    I called 2brothers and they are going to send me the missing bushing that I need that normally come with the exhaust
    UPDATE - the space arrived yesterday (Kudos to 2brothers support!)
