Vibration
.It sounds like you need a laser alignment. Check with your dealer. You could also have a front tire that is not perfectly round.
2020 F3 Ltd
Spyderpops Bumpskid
Spyderpops Brake/Run/Turn Signal LED's
Lamonster Garage LED Fog Lights and Headlights
2013 ST-S retired 1/9/16 at 25,061 miles
2015 F3S sold at 77,565 miles.
, your dealer can do an alignment but most dealers can not Lazer Align it, which is probably what you need.
Cruzr Joe
More likely a tire(s) problem (balance, out-of-round, separated belt, etc) than an alignment problem. I have not heard of a laser alignment correcting a front end vibration or wobble issue.
2016 F3-L Special Series? Mods: Lamonster IPS end caps w/ Gripper 3rd pegs, GPS mount, Power Plate, Perf. Muffler; Backoff Brake Light Strobe; CD Front (amber/red) Brightsides & Tip Kit; ISCI Flag Holder w/Long Poles; BRP Signature Light, Aux Lights, Saddlebag Liners, Garmin 590 GPS; TricLED foam Grips, LEDs (Aux/headlights); Pitbull Driving Lights; RDL seat; Ultimate backrest
Previous ryde: 2012 RT-L, 26,636 miles on it when traded; 2014 RT-L, 34,147 miles on it when traded
Originally Posted by screaminspyder14
Yesterday was the first time that ive had a chance to get on the interstate with my ans when I get up to about 65 I am getting a bad vibration in the handlebars and anything over 70 mph is really bad.Im hoping that someone on the site can guide me in the right direction so when I take it to the dealer I will know what to tell them. Any help will be greatly appreciated. I really love this site. Be gentle with me im new to the world coming off a harley triglide.I have alot to learn.
I had the same problem. Bought my new 2014 RT last week. The dealer replaced my front tires. BRP told them to because there are several hundred lots of tires that are bad. Take it in. Mines rides smooth as silk now.
Pull the front wheels off and take them to Mocks Tire on Stratford road just past the Honda/Can Am dealer and have them balanced on their Road Force balancer; this will tell you whether they are perfectly round or bent in any way; likely not, and just need balancing which may well solve your problem. Its worth every penny of the $1o bucks they charge per tire. I had mine done there and they are very familiar with doing Can Am tires. They can't remove them so you'll have to do it...something about they're not allowed to work on "motorcycles". After this, if it doesn't solve your problem, take it to the dealer for a laser alignment. BTW, torque on the front wheel nuts is about 80 ft lbs.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Mine is at the shop for basically the same thing. Except at speeds of around 50. Rebalanced the tires, installed new tires, still didn't fix the problem. Seems that the 2014 also is having issues with the front shocks. BRP is sending out new front shocks, hopefully this will cure my issues.
thanks
Thankyou for all of your advice.
Laser Alignment
I have a 2014 RTS SE5. The first time I got to 70mph was on the way to Spyders In the Redwoods. Had put about 400 miles on it before this but never freeway. At 70 and higher could feel vibration through my feet and a little in handlebars. Had an appointment for a Rolo laser alignment with Squared Away at event. After the alignment, on the way back home on freeways vibration gone!! Thinking you should seek out laser alignment before spending money on new tires.
SpyderLovers Sponsor
Most likely tires and or wheels are bad. Could also be something as simple as balance. Not uncommon.
Get that fixed and then get a quality laser alignment. That should give you a new outlook on life in the Spyder world!
Take it back to the dealer there problem not yours. Shouldn't have to pay anything
