Results 1 to 24 of 24
    Invalid Emails
    Oct 2013
    Campobello, SC
    Default Replacement fuel gauge
    Does anyone know of a replacement for the fuel gauge currently on my 2013 RT-S? The gauge just stinks never showing the right amount of fuel in the tank. I wonder if there is a replacement that will read the fuel more accurately than the one we all have. Anyone have any suggestions or ideas?
    western Colorado
    Quote Originally Posted by swmp321 View Post
    you can disconnect it and use the digital one on the main screen
    Very Active Member Pennyrick's Avatar
    Feb 2011
    Loganville, ga
    The digital gauge comes up on the right side with a bar indicator.
    Penny and Rick have owned many motorcycles starting in 1974 with Honda’s, then to Suzukis, Gold Wings and ultimately Spyders.
    ‘74 Honda 360T (pair); ‘78 Suzuki GS 1000 (pair); ‘’82 Honda Aspencade; ‘84 Honda 400; ‘87 Yamaha 1100; ‘99 Honda Valkyrie; ‘01 Suzuki Burgman(triked); ‘02 Honda GL 1800(triked); ‘10 Spyder RTSE; ‘11 Spyder RTSM; ‘12 Spyder RTSL (pair); ‘20 Spyder RTL (current)
    Active Member philblumenfeld's Avatar
    Usa
    How do you disconnect the old one and can you have both?
    Just remove the "pod", that the auxiliary guages are hooked to, and the attachments are very clear.
    You'll have to wiggle the bars a bit to get everything loose from the bike, but it's actually pretty easy.
    Usa
    I'm sorry, what is the "pod"?
    Very Active Member freebob's Avatar
    Apr 2009
    Bluffton, S.Carolina,USA 29909
    Default Instrument cluster
    Quote Originally Posted by philblumenfeld View Post
    Better known as the.... Instrument Cluster Assy. Four scews hold it in.....
    Freebob..
    Nov 2013
    Central Texas
    Quote Originally Posted by Rattigan_Roger View Post
    No.
    And you can't have just the temp gauge or just the gas gauge.
    And you can have only one gas gauge.
    Disconnect the gas gauge and the temp gauge will read off scale, disconnect the temp gauge and the gas gauge goes to zero.
    So really the only solution is to install a new gauge such as you did, is that correct?
    I would not recommend going for a replacement gauge. I had three on my 2010 and finally said "enough." Disconnected the analog gauges on both the 2010 and the 2011 and then used the digital gauges that are already programmed in.
    Many have also installed auxiliary gauges to replace the gas/temp gauge set up.
    The gas gauge on the 2014 RT is rock solid and the refuel light seems to come on at the same place on the gauge each time. Just below the top of the red section at the bottom.
    I still do not rely on the gas gauge. Always set a trip meter to zero when refueling. As I near 200 - 205 miles or so, the refill light goes on. Usually 5 gallons and some change. Averaging 40 mpg now.
    On my 2010; both fuel gauges that I used were... close guesses at the best!
    I learned to ride by the trip odometer...
    But the 2014; that gauge is about as accurate I've ever had in ANY vehicle!
    Now; I trust the gauge enough, to ride by it!
    Default Easy..!!
    you can pull the four torx head srews that hold the instrument panel on and get to both guages. Be sure to put a towel around the neck of the steering column to keep from loosing those screws to the black hole gods... You can replace those guages with volt meter, battery condition, altimeter, oil pressue etc. The temp and the fuel will then be digital on the main screen and very accurate...
    ​2012 RS sm5
    Active Member NorCalBud's Avatar
    Feb 2013
    Northern California
    Default Fantastic Advice!!!
    I once had my key slip from my fingers when starting my Trike and it slid right down into that abyss.... I was SOOO lucky to have been at work where I had a retracting grabber tool to gently fish it out...not my finest Spyder memory!
    ~'12 RT Limited, Pearl White~
    BajaRon Anti-sway Bar
    Squared Away Laser Alignment
    Custom Dynamics HMT Brake Light, Front Fender Tips & Kit, Front Mud Flap LEDs, Amber & Red Brightsides, Tri-color Magicflex Channelz
    Lidlox Grip Tip Helmet Locks
    TricLED Mirror Signals, RGB Multi-color Halo Underground Effects Kit, LED Headlights
    Palmer Signs Custom "Captain America" frunk graphics
    Twisted Chrome Pinstripes
    Overland Australian Sheepskin Seat Cover
    Bossier LoUiSiAna
    Why do they not offer gpm as some newer cars &trucks have?
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Feb 2011
    Loganville, ga
    Gallons Per Minute??????
    Invalid Emails
    Oct 2013
    Campobello, SC
    Quote Originally Posted by Double Trouble View Post
    Mine doesn't. In fact I have no gauges on my display. If there is a way to set them to pop up, please let me know.
    Feb 2011
    Loganville, ga
    Have you completely disconnected the leads to the analog gauges (both temp and fuel)?
    The digital gauge bar graph for temp comes up on the left side and the fuel comes up on the right.
    Invalid Emails
    Oct 2013
    Campobello, SC
    No, I haven't done anything to the gauges. I was hoping there was a setting in the display to make the temperature and the gas gauges to come up.
    Feb 2011
    Loganville, ga
    No. You have to remove the dash panel (4 screws) then turn the bars hard left and wiggle the dash panel out so you can see the electrical leads on both gauges. Disconnect and tape the bare wires so they don't short anything unless you are going to install other analog units such as voltmeter and oil pressure then you can reuse them.
    Replace the panel and start it up. As Roger says the digital readings will then appear.
    The analog units are no longer connected.
    Invalid Emails
    Oct 2013
    Campobello, SC
    Thanks!
    Bossier LoUiSiAna
    Gallon per mile or in can am term gpk. Point is the computer systems are available now so incorporate it
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Active Member Gundam's Avatar
    Dec 2013
    Singapore
    Default Analogue fuel and water temp gauges
    I modified mine with a switch so that I can use either analogue or digital guages, selectable on start up... incidentally, my analogue fuel gauge is rather accurate, stable and consistent....
    May 2013
    Stanton, ca
    All of the electrical connections should be removed from the gauges.
    The digital gauges will appear after start up.
    Actually you can flip the connectors upside down (so the sense wire is not connected) and still have the lights work in the analog gauges.
    I did this for a while until I finally decided to use the holes for the analog gauges for something else.
    Bob
    2011 RT-S SM5 - Black
    Bossier LoUiSiAna
    Wow yall i typo *mpg*
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Very Active Member jthornton's Avatar
    Feb 2013
    Poplar Bluff, MO
    Here is my instructions for adding a Dual USB to the dash which shows you how to remove the dash.
    http://gnipsel.com/spyderpdf/DP-1.pdf
    JT
