Results 1 to 19 of 19
    Sep 2013
    Maine
    Default Brake failure light
    Its on and off on and off. Can't figure it out? Brake fluid is full. Is it safe to drive?
    washington state
    I don't think the light controls the function of the brake system. It indicates issues. Check your brake pads, linkage, fluid.
    2012 Spyder RT SE5 Brake pedal mod
    Very Active Member bruiser's Avatar
    Eastern North Carolina
    Can you pull up any codes?
    USAF '69-'89 E7
    Thailand/Vietnam 1972
    Default Agree..!!
    if when it happens try to pull up the codes. If none are present start with adding a bit of fluid even if you think it is full. Check the sensors at the reservoirs then check the brake pedal switch and brake light bulbs. Then move on to the pads etc. This in no particular order...
    ​2012 RS sm5
    Sep 2013
    Maine
    Default brake failure light
    No codes. I am 150 miles from dealer!
    Active Member ABQAndy's Avatar
    Nov 2012
    Albuquerque, NM
    The brake fluid level sensor is very sensitive so I would guess that you just need to add a little fluid to the reservoir and the light will go out. That's happened to me several times. Should be safe to drive.
    2012 Spyder RT Limited
    Guardian Bell (gift from son)
    Spyderpops bumpskid
    ISCI hand brake
    BajaRon Anti-Sway Bar
    BRP Adjustable Wind Deflectors
    Apr 2012
    Northglenn Colorado
    Quote Originally Posted by ABQAndy View Post
    Same for me. Its probably the front brakes so it would be the reservoir to the rear of the Spyder. Just a tablespoon or so. It might look full but it has to be almost touching the cap.
    Active Member Chief-J's Avatar
    Apr 2011
    Fort Belvoir, VA
    Default Brake Light
    When my Brake warning light did that, it turned out to be my Parking Brake Cable. It was broken and would not engage to hold the bike. Good luck.
    Very Active Member bscrive's Avatar
    Nov 2012
    Ottawa, Ontario
    This just happened to my cousin. It turned out that the fluid level sensor in the reservoir under the seat was stuck to one side. Her husband took a screwdriver and straightened it up so it could move freely and now the message is gone.
    Mar 2012
    NJ
    IMHO the sensitivity of those sensors is ridiculous! Its either throwing a warning or puking periodically from the caps.
    I eventually just pulled the sensors out from under the reservoir and was able to run a lower fluid level in the reservoir. No more puking fluid, no more warning lights.
    With the size of the reservoir, length of the reservoir lines in relation to the size/movement of the calipers/thickness of the pads, there is NO reason to have that size reservoir and the oversensitive sensors.....
    I think the above posters have the issue covered pretty well. Most of the time, I have found the fluid container reservoir was about a teaspoon to a tablespoon low.
    RodMyers
    Guest
    Mine has been in the shop 4 times fire brake failure, with no codes. The last time, they replaced ; brake cable, park brake rear pulley, and cable pulley. Was running good for a week and a half, then a hard braking and back. Now they are replacing master cylinder
    Sent from my GT-N8000 using Tapatalk
    Jan 2013
    W.NC
    Default Same here
    Drove me nuts trying to figure out what was wrong. The fluid levels aren't noticeably low but enough to flag a brake failure notice. Had me worried coming down Pikes Peak! A small amount of brake fluid solved the problem. Hope your's is an easy fix, let us know.
    Default BRAKE FLUID
    Quote Originally Posted by StillKickin View Post
    ........annnnnnd treat Brake fluid the same way you would ...SULFURIC ACID....I'm not kidding.....you do not want to get even a drop on ANYTHING......I use the metal TABLESPOON METHOD .....I don't fill it just a small amount .....this way you are less likely to spill it..............and put in a small amount at a time ...you can always add .....also be careful not to get any dirt etc. into the brake fluid container on the Spyder...................good luck ..............Mikeguyver
    Sep 2013
    Maine
    Default brake fluid
    3 dot or 4?
    Jul 2010
    Las Vegas, NV
    Default Fluid
    DOT 4
    Joe Meyer
    Registered Users Spyder ri's Avatar
    Warwick, RI
    I just use the cap as the filling tool.
    RodMyers
    Guest
    The local dealer replaced the rear master cylinder, and it appears to have fixed my issue
    Jan 2013
    Florida
    Thumbs up
    I use a 20cc syringe. No mess
