cat pipe
has any replace their cat with the replacement pipe
er uh,,
search is your friend
Lots have. Makes for a happy bike and a happier rider.
Lamont has a cat by pass. I have one and like it.
4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
I have replaced it on my SM5 ST. I love the differnce it has made to throttle response, and a little increase in power, but love the new sound I have coming from my Debaffled Akrapovic.
Its not a Lamonster one, as I am in New Zealand. I managed to get one from Australia
it is slightly different to the Lamonster one. The 2 pipes from the headers come down and join at a Y joint just before the
mounting point to the Muffler, where the Lamonster one has one pipe integrating into the other with out the Y joint. Siamese I think they call it.
My pipe is the same as the top pic here, and the bottom pic is a Lamonster Pipe
We now have His and Hers Spyders.
Current Spyder, 2015 F3 Steel Black, Passenger Backrest, Blue Ridge Screen with Xcreen Extention, Akrapovic Muffler, Attitude Handlebars, Blades front rims, RT Swaybar,
Her Spyder 2011 Magnesium RSS Sportrack and Backrest, Comfort Seat, Grip Puppies, 3.5 inch Riser Bars, Wespyd Signature Swaybar. Hindle Muffler, Godiva Screen, Hiway Pegs Can Am Panniers
Previous Spyders
2013 ST SM5
2011 RSS
2010 RS
hundreds have
Replaced cat with bypass
Had my cat replaced with a LaMonster style bypass on my 2013 RT Limited. Reduced heat under the seat (it's still noticeable, though), increased mileage and responsiveness at lower RPM (thus probably better torque from the reduced back pressure) and a throatier sound from the exhaust. Have noticed some tendency for mild backfiring when I engine-brake by downshifting a couple of gears on a downgrade.
With these by pass, is it ok with nanny? Plug and play?
2012 Spyder RT SE5 Brake pedal mod
