Brake Longevity Question
How long does a set of breaks last on a '12 RT?
Kagey
Do not mess in the affairs of dragons, for you are crunchy and taste good with ketchup.
Spyder RTS SE5 - Quantum Blue Metallic - LED RT HMT Brake Light W/Dual Converter Unit - Lamonster NBV Highway Pegs
SpyderPops "Missing Belt Guard" - "Butt Buffer" Butt Pad - Utopia Backrest - Original Grip Buddies - Digital Volt Gauge
Analog Clock - Shark LED Light Kit - BajaRon's SwayBar - Mud Flap - Custom Dynamics Radiator Inlet Covers
Seal FloorBoards - Baker Air Wings - SpyderPops BumpSkid
SpyderLovers Sponsor
Depends. Average on the rears, 10-15k. About twice that on the fronts. Some need them a 8k and some get 20k out of the rears.
My 2011 Rt got 12,000 on rear and still have original front that have 22,000.
4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
Its going to vary because of a gazillion reasons.
My 2010 with 35,500 had the original brakes. I try not to use them much. Accelerate into curves, engine braking for down hills.
Hard to say..!!
many variables. But if you can measure your wear so far you can estimate. As mentioned above using engine to slow down and mastering you corner approaches will help. Then you have your style, solo/double, trailers, weather and road material to name a few. Seems we see many wear items in this position. I have 22,000 miles on all my pads but it is an RS...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
On my 2010 RT-S the rears were paper thin at 20,000 miles. I was at the dealer having a rear tire changed and the service tech came and got me to show them to me and I went ahead and had them change the pads. (it is much easier to do with the back wheel already off). The fronts still have quite a few miles on them. I am now at 24,000 miles total. As explained to me the braking is 60% front and 40% rear. The way I see it, the fronts have 30% each and the rear is 40% and it makes since that the rear does more work than one of the fronts causing it to wear faster. By the way, I have pulled a 622 trailer for approx. 8,000 miles of the 24,000. I was surprised that the rear brakes were wore out before the fronts but that is just my "car mentality" coming through. Things are much different with a linked braking system.
Happy Spyderlovers
Agree with all of the above. I have 34K on my original brakes on my 2011 RT. Always downshift and stay off the brakes in corners. Pull a trailer some but most miles are 1 up rural roads. I think it makes a difference if you have a SM vice an SE.
Still have about 40% left on all wheels ...
Bill
Pride Runs Deep Semper Tacitus
An armed man is a Citizen; an unarmed man is a subject....
2017 F3 T SE6
2015 Vulcan Vaquero ABS
ALR Chapter 401 (Hilliard FL)
GA & FL Patriot Guard
Kagey
That is like asking how high up is.
Penny and Rick have owned many motorcycles starting in 1974 with Hondas, then to Suzukis, Gold Wings and ultimately Spyders.
74 Honda 360T (pair); 78 Suzuki GS 1000 (pair); 82 Honda Aspencade; 84 Honda 400; 87 Yamaha 1100; 99 Honda Valkyrie; 01 Suzuki Burgman(triked); 02 Honda GL 1800(triked); 10 Spyder RTSE; 11 Spyder RTSM; 12 Spyder RTSL (pair); 20 Spyder RTL (current)
Originally Posted by Double Trouble
Kagey
Now that's an easy one - 2 feet
2021 Sea To Sky, 2020 RTL
but our benefits don't?
It's not a 2012, but our 2010 RT has 49,400 miles and still has the original brakes all around. When the rear tires gets changed again, the rear pads will be replaced.
2008 GS SE5 in 2008
2010 RT SM5 in 2011
Wait....it has brakes?? Why don't they tell me these things....
Man....after I installed that anchor and electric windlass for it.....
Eric
YNC(SS) (Retired) - U. S. Navy Submarines
2014 RT-S Cognac
3 seadoo's,CBR250R, Suzi GT750 waterbuffalo's x4, Rebel 250, MB5, '84 Alfa Spider, '97 Jeep TJ, '93 Saab C900CVT, '99 SLK230, '65 Mustang, '59 Fairlane, '48 Ford 8n
squeaking front brakes
My RT-S has 1000 miles on it. The front brakes always squeaked . Anyone know what causes that? I understand it when I am first starting a ride but after its warmed up? That doesn't make sense since the brakes are new. This has happened since mile 1.
