ST Windshield Bobble Head Affect
There seems to be a plethora of windshields advertised for sale and re-sale, but few are designated for ST's. With that said, can the brackets on a 2013 ST accommodate a windshield from an RS or an RT?
I have the stock windshield (19" I believe) and while I'm 6'4" it doesn't direct airflow over my head. Thus, I actually have to keep it down a notch otherwise the wind is directed straight into the middle of my helmet, causing me to look like a bobble-head!!
So, my objective, will be to get a windshield that can deflect the air above my riding profile, but also maintain adjustability in the original brackets so I can lower it during the hot Texas summers to get some cooling effect!
Thoughts, insights for other ST geniuses out there??
Thanks,
Jon
SmoothSpyder Backrest | Removed 'CanAm' graphics | ThermoTech II Wrapped Exhaust | 2014 Vented Side Panels | BajaRon Sway Bar | BajaRon Heim Links | Bump Skid (via SpyderQuest & SpyderPops) | Rivco drink bracket, reversed, with X-Grip for phone holder | BRP Ultra Touring Windshield | Givi Hard Saddlebags | Russell Day-Long Seat
ST Windshield
Jeff M.
2017 F3-Limited
...in the pink (Girls On Spyders)
Check out calsci....the best...designed for st
#IamARyder #RideASpyder #CanAmSpyder
6'3" 280lb Big Daddy
Thanks,
Jon
I'm 6'3" 280lbs and my head and eyes rattle like crazy on my 2014 ST-S with the windshield it came with. The only thing that helps a little is to tighten my helmet and goggles 'real tight' and slow down on the highway (which is boring at times). Did you ever find anything such as a replacement windshield or other that'll help this issue???
Reason: Enter model of spyder and speed limit
Using the stock windshield I figured out a lot of buffeting came from the wind wrapping around the sides so not a lot you can do. I just replaced it with the Ultra Touring windshield. I've only had a chance to ride about 70 miles but I can definitely tell a difference.
Without an upgrade be sure to adjust your visor to cut out wind noise (if you wear a full face helmet) and that helps a lot. Otherwise I just got used to the buffeting.
Yeah...
I wore glasses all of my life until I got lasik last year and it seems my eyes are a bit more sensitive to vibrations.
I am assuming this you are reporting somewhat of a positive difference in replacing your stock with a Ultra Touring? Where'd you get it?
I have yet to find a full face helmet that is comfortable...so thus far, I'm really happy with the wind with my half helmet. Yeah, I know that'll give me more buffeting/vibrations but there's got to be something that'll help me. I saw a guy on an RT this weekend wearing prescription glasses with no straps and he was fine...must've been that windshield huh? IDK.
Yeah, most RT's have a windshield that creates a very large pocket. Several people suggest the Cal-Sci windscreen... I strongly considered them but went with the BRP Ultra Touring Windscreen. The reasoning for that decision is the BRP Ultra is made from Polycarbonate, where the Cal-Sci is an Impact-Modified Acrylic... but it still doesn't come close to the breakage resistance of Polycarbonate. You can order the Ultra through the BRP website, or your local dealer... I was able to negotiate mine down to about $210 if I recall.
There is still a bit of wind-wrapping from the sides, but not nearly as much. And when I duck down into the pocket... it is absolutely silent... I'm very impressed so far, but like I said, I've only got about 70 miles under my belt with the new windscreen!
As for helmets, I'm a big fan of full-face due to wind / weather resistance and safety. If you're considering one and put an emphasis on safety, I'd be sure to get a helmet that is not only DOT certified but also SNELL. Personally, I use a Shoei RF-1100. And remember, how the helmet feels in month 1 will be much tighter than how it will feel in month 3... the cheek pads need to break-in! Plus, i have a bluetooth system on my helmet so I can communicate with others, talk on the phone, listen to music, etc. all in my helmet, which sounds waaaay better than blasting it through the stock system. In fact, I can be up to 75mph and most people had no idea I was on a motorcycle... it's a SENA SMH-10R.
Hope this helps!
NoLmtz
image.jpgHere is what I came up with and have about 40000 miles on it and it works.
Sidebar from his wife: Butch is 6'4" also and had the same issues as yourself...this attachment is from Baker Air Wings and can be tilted on the fly if you want air dumped down at you to cool off on hot days...otherwise it directs the air up and over his head.
[SIGPIC][/SIGPIC]Spyder Owner Since June '08 & April '12
Calsci windshield
We're very happy with ours.
I cannot find the attachment
Hey...I looked and cannot find this attachment on their site. Do you remember what this attachment is called or have a URL?
i did a cali. sci. with angle adjustment brackets from Australian spyder ryders.
