2014 RS-S at HD Dealer 1800 miles what's it worth or should I run away?
I found a 2014 RS-S at a Harley dealer with only 1,800 miles on it!
What is it worth and even if I can get it cheap is it going to be a major PILA?
If I can get it for a good price I would run to a "Real" Can-Am dealer and get it checked out and buy an extended warranty.
Assuming I could get a good price should I do it or should I run away from it quickly!!
Try looking it up at:
www.kbb.com
Happy Hunting!
back ground check
take the VIN to a spyder dealer. they can tell you it's maintenance history. it should have plenty of warranty left, which you could extend. if you could get it cheap, it might be a hell of a deal. the hd dealer would likely want to unload it quick. try to lowball. you have nothing to lose.
it was fun while it lasted.
I bought my first Spyder from a Harley dealer. Do your research, test ryde it, make a deal!!
Good luck!
Tags for this Thread
