Michelin (hydroedge) Defender rear tire pressure
Does anyone know what tire pressure I should run in a Michelin Defender( replaced the hydroedge-same tire different name) I have used 2 kenda's this year because of center tire wear. I have run them at 24-26 lbs. with no discernible difference. So I purchased a Michelin, hoping for better mileage. The tire says 40lbs. but that just doesn't seem right on a bike. I was thinking 30-32 lbs but will take any advice given. Thanks in advance. Jim
2013 RT-S se5, C/D HMT third tail light( r/b/t), Ram Cup holder, TRICLED front fender LED's (r/t), C/D Bright sides (r/t), Bajaron sway bar and metal heim links, TRICLED mirror turn signal LED's, ISCI tall dual flag holder, BackOff LED license plate frame, "Rufus" (stuffed 20" Bulldog) real one wants nothing to do with bike. Honel tri bag for dash, recordingguy25's (SL handle) custom mud flap ( didn't want plain old square cut mud flap. Spyderpops critter gitter. Gremlin Bell
use 26 to 28 lbs, works best for me
I just bought a Hydroedge and I'm going to try 28 psi. They mount it Friday.
the tire only states its' maximum air capacity it never knows what it is installed on
That's what I'm thinking too. So, I'll start with the factory recommended 28 psi and keep an eye on them. They gotta be better than the Kenda's The Defender may be the same, but looking on-line they have a different tread pattern than the Hydroedge
Rear tire on spyder is Kenda Use 30psi would think that it would be around same pressure for spyder
Pressures..!!
always start with the vehicle pressure recommondations. You have to find the best ryde for your weight and style from there. Someone mentioned placing a chaulk line on the tire and rolling around to see if it erases even. This could help but tires baloon at speeds wearing the middles faster. For wear I would run on the lower side...jmo
2012 RS sm5
Originally Posted by georam
BRP
COLD TIRE PRESSURERECOMMENDATION:
Front
Nominal 15 PSI
Minimum 13 PSI
Maximum 17 PSI
Running your Kenda front tires at 24-26 lbs. is why they are wearing in the center. I have Bridgestone Potensa RE92 165/65R14s. I run 22 PSI and I am very happy with the tires.
Those tire pressures are for the FRONT not the rear that we're talking about. And what year book are you quoting, the year makes a difference in what BRP has reccomended for tire pressures.
RT-S PE#0031
I've been running 28 in my rear Michelin HydroEdge for a couple of year. Wear pattern is even.
The pressure stamped on the side of any tear is the Maximum pressure for that tire. Tire manufacturers (not talking about tire retail stores) generally will tell you to go with the vehicle manufacturer recommended pressure.
Mark & Mary Lou Lawson
Snellville, GA USA
'10 RT-S PE #0031
'10 RT-622 Trailer
'08 Yellow SM5 #2332
'01 Black GL1800A Goldwing #0930
"Remember in the darkness what you have learned in the light." - Joe Bayly
Mileage? A couple of years infers that it's lasted well for you.
Got around 21k miles on my Hydroedge probably another 5k left
2012 RT A&C bought new 42312 sold July 2018 56k miles currently driving a 2014 RTSE6 LTD bought October 2018 w 6800 miles nicely farkled
Thanks to all of you that responded to question. I'm going with 28 Rear, I just cant do 3 kendas a year. I run my front at 17.5 to 18 and rear has always been 25. Thanks again, we'll see how these do.
Good luck and we'll keep each other informed on how we do 21,000 - 26,000 miles is looking pretty good to me after going thru a Kenda in 6500 miles
RT-S PE#0031
As I am at work right now, I cannot take a look at the odometer to tell you. I did do a post on this tire sometime back & you might find something useful there:
http://www.spyderlovers.com/forums/s...ction-Evidence
Snellville, GA USA
'10 RT-S PE #0031
'10 RT-622 Trailer
Thanks Mark, interesting read. I guess I lucked out because when I walked into my Michelin dealer and asked for a good rain tire in 215/60/15 he looked and he had two remaining Hydroedges in that size in his warehouse. I probably should go back and get the other one if this one works out.
What size did you buy I do not see it sold in a 225/50/r15 size
2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
Doesn't this answer your question I think they are going to work just fine Plus I didn't have the luxury of sitting around and waiting. I'm headed out on a long trip up into Canada if a few weeks and my Kenda on the rear is shot enough so I wouldn't trust it on a long trip
I am running a hydroedge at 28psi and is wearing even. Should get great milage by the looks of it as in 3500 miles only down 1\32. Tire started @! 10/32. We run two up always.
2012 RT Limited
Vertika Floor boards
Painted rear fender & dash
Carbon fiber panels
Utopia back rest
Baker air wings
Elka shocks and relocaters
CB radio
ISO hand grips
Tric LED fender light
Turn signal lights in mirrors
